Old 09-03-2021, 02:01 AM   #1
jarrodblake
jarrodblake's Avatar
engine speed sensor/ crank sensor wiring for tachometer 97-98 sensor
I installed a 97-98 engine speed sensor/ crank sensor to run my tachometer. I have already ran a 5 volt power, ground and sender wire for it but I can't find the pin out.
here is a pic of the plugs the one with the 123 is the harness side the the other in the sensor.
I need to know where the power, ground and sender wires go on the 123 plug.
Here is a pic of the sender I am using.
jarrodblake is offline   Reply With Quote
Old 09-16-2021, 05:49 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: engine speed sensor/ crank sensor wiring for tachometer 97-98 sensor
I just went through this a couple years ago when I did a 6.4 12v swap. I'll see if I can find the info again.
On edit, I found it. It was in the instructions for the swap helper tach box I used. Sorry the image is side ways.
1 is 5 volt supply
2 is Sensor ground
3 is Crankshaft position sensor signal
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-16-2021, 11:08 PM   #3
jarrodblake
1 is 5 volt supply
2 is Sensor ground
Thank you!
