Old 09-03-2021, 09:22 PM   #1
BuffDrinkLots
Alternator Extra Wire Help
Hey all,
I’m sure this has been discussed thoroughly, but could not find what I needed.
My situation:
1972 C10, External Regulated Alternator (DL7133)
In pic 1 is the wiring from PO, it has a plug in black and yellow wire, and one wire at the Batt location.
In the others pics, is the new factory wiring harness, it has the plug in white and blue wires, red Batt wire and an extra wire that I think is brown or black that the alternator never had previously. I am assuming it’s a ground? Where does it go? I was just gonna bolt it either to the frame or put it with the batt and put the rubber boot over both. I don’t see anywhere on the alternator that says “ground”. Any help would be awesome! Thank you.
BuffDrinkLots is offline   Reply With Quote
Old 09-03-2021, 10:12 PM   #2
mr48chev
mr48chev's Avatar
Re: Alternator Extra Wire Help
Backtrack the other end of the black wire but I am thinking that you are correct and that is a ground wire to the Ground bolt on the alternator.
I haven't had an external regulator alternator on mine for years as I changed mine to 10 SI and now a 22SI that came with the Cad 500.
The top photo shows the external regulator alternator hookup on my 71 per the wiring diagram from www.classiccarwiring.com The second shot is the wiring diagram
Big enough and plenty nice enough to put up on the wall of the garage by the truck. They aren't cheap but when you get it laminated it is a nice piece to have to refer to.
My ongoing truck projects:
Old 09-04-2021, 05:28 PM   #3
BuffDrinkLots
Thank you! Appreciate the help, the diagram helps a lot. I’m gonna ground the wire and see what happens, it’s the only thing that makes any sense.
Old 09-05-2021, 06:01 PM   #4
basketcase
basketcase's Avatar
That extra black wire and the bracket on the harness mount onto that alternator ground post.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
1972, alternator
