![]() Join Date: Jul 2001
H/L & 4WD Switch-Dark,No See-um
2005 Tahoe with the push button AWD/4WD switch and the four position head light switch......all dark at night, no visible illumination at all. Am guessing maybe the LED (?) lights are burnt out? Are the internal lights serviceable or must one replace the entire switch to have the lights functioning again? My guess is the later as it seems Nothing is serviceable when it comes to cars and trucks now days.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Moderator
![]() Join Date: Oct 2008
Re: H/L & 4WD Switch-Dark,No See-um
You can replace the illumination lamps. They're around 4mm tungsten filament bulbs with blue silicone caps soldered to a circuit board or in a holder.
You can use LEDs but the light won't match the rest of the dash and door switch lamps. The tungsten bulbs typically last around 15 years so they'll outlast your ownership of the truck. I did my headlamp switch. The dimmer got flaky a few months later so I replaced the switch. Didn't even think to look at the solder connections. The switch was pretty nasty so I didn't really want to keep it. The illumination bulb is mounted in a little 1/4 turn holder. IIRC the switches were not expensive at all. The plastic on the 4x4 switch was super brittle and it cracked even tho I used guitar picks slid down along the sides between the inner and outer parts of the switch body to release the plastic from the projections rather than push the plastic wide with a spudger. The bulbs and switches are mounted to a super thin printed circuit board inside. The other problem is the 4x4 switch has high density .010 pin pitch connectors that are molded into the rear of the switch housing. To replace the bulb you need to desolder the PC board from the connectors and once the bulbs are replaced you need to solder the board back to the connector pins. I would highly recommend that you use a vacuum desoldering station. The switch board is super thin and it doesn't dissipate heat as well as a standard thickness board and the density of the pins is such that it's difficult to get all the solder out of the holes with braid and/or the spring-loaded solder suckers. You'll end up with lifted and torn pads without the proper tools.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-29-2021 at 03:27 PM. |
Thanks for the reply. From reading your post not sure these old hands and eyes are up to that sort of delicate work. May just wind up buying new switches and going on from there. That sort of soldering such small wires and boards, not sure I want to attempt that. Sure is tough getting old but it beats the alternative.
Moderator
The headlamp switch is fairly easy. No soldering outside of possibly touching up cracked solder joints on the connector pins on the board. Look at Jeffs' video that I posted.
The 4x4 switch is fairly difficult to fix and I've done board repair like this. I did fix the switch that came out of my truck despite the cracked plastic so I could have a spare. I wouldn't attempt this one if you aren't supremely confident in your soldering and PC board rework skills.
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-29-2021 at 03:35 PM. |
![]() Join Date: Feb 2000
There are a few places out there that will replace the bulbs with LED's for you such as https://carradiobulbs.com/store-4/03...grade-service/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Moderator
The 4x4 switches are so cheap it's not worth sending em out. I think I paid $35 for mine.
After you get done with shipping both directions and paying for the tech it'll cost more than that. The only way it's worth fixing is if you can do the work yourself.
And please let us know if and how your repairs were successful. |
Just a suggestion for those wanting the option of having it fixed and LED's installed that cannot do it themselves.
Thanks for the replies and info. I'm finding out more and more with the newer vehicles somewhere down the line I got left behind in the tech department. I pretty much cut my teeth playing with carbs, points and condensers, changing plugs every 10,000, oil every 2 or 3 thousand miles. These newer vehicles sure aren't very user friendly to that type of background at all. Pretty sure will be visiting with my local trusted mechanic shop for a fix.
#9 | |
Moderator
![]() ![]() ![]() Don't be frightened of the new machines. Nothing ooogie booogie about the electronics. Soldering circuit boards is a rarely needed talent. You can find videos about troubleshooting and most maintenance and repair operations. Lots of good folks here too.
