Old 10-08-2021, 10:12 AM   #1
theomajigga
Searched but just want clarification 4wd conversion
Doing a 2wd swap into a 4x4 frame.
As I understand it, almost anything 73-87 2wd will fit with minor modifications.
2wd pickup gmc/chevy, blazer(jimmy), burb.
I'm also reading that up to 91 blazer/burb will also work?
Want to do the front crossmember and the rear axle, eventually get an LS into it, so LS adapter plates for whatever front crossmember I get and trans mount.
I did search, there was a post that basically confirmed this, but I wanted to make sure, and also see if I can go up to 91 blazer/burb front and rear ends.
Thanks all.
theomajigga is offline   Reply With Quote
