Old 11-03-2021, 11:42 AM   #1
JDon99
Narrowed Rear With OE Trailing Arms?
I'm gathering up parts for my 66 SWB street/strip build, and looking to have a 9 inch built by Strange for the trialing arm setup. I was considering going slightly narrower than the stock width(2" per side). Have any of you guys ran a setup like this? I just want to make sure there won't be any clearance issues. Thanks fellas!
JDon99 is offline   Reply With Quote
Old 11-03-2021, 04:58 PM   #2
SCOTI
SCOTI's Avatar
Re: Narrowed Rear With OE Trailing Arms?
At 2" per end, you shouldn't run into any issues. E-brake cable routing/attachment might require finesse depending on the set-up (might).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-03-2021, 05:30 PM   #3
JDon99
I'll probably go with a set of Wilwoods with a. 11 or 12" rotor.
