Old 11-05-2021, 07:04 PM   #1
chevyrides
Vacuum fitting on manifold
My manifold is missing the fitting for the brake booster hose shown in photo. Can you buy that fitting? My son has one on a manifold that I was going to try borrow. I tried remove it but it didn't want to come out. It will spin easily and move a little bit, I didn't want to try too hard and break it. Has anyone removed this fitting?
chevyrides is offline   Reply With Quote
Old 11-05-2021, 09:05 PM   #2
Thealien
Thealien's Avatar
Re: Vacuum fitting on manifold
You can buy those or find one in a junk yard. It is a typical push loc type fitting. To get one out of a manifold you push the red ring and pull on the fitting.
Old 11-05-2021, 11:20 PM   #3
chevyrides
Thanks for the reply, I would like to remove the fitting that has the red ring, that is the part I'm missing
Old 11-05-2021, 11:29 PM   #4
chevyrides
This is the part here.
Old 11-06-2021, 06:10 AM   #5
Thealien
Thealien's Avatar
I am not 100% sure but I believe that is part of the manifold and if it is missing I believe you need a whole manifold? Do you have a picture of your manifold in that location?
Old 11-06-2021, 10:37 AM   #6
chevyrides
I can't really get a picture of the manifold in that location, it fairly tight up against the firewall. In the picture of my sons manifold above it looks like it's part of the manifold but it's not I can freely turn it by hand. After it was installed at the factory it was probably not meant to be removed. I think you may be right and would have to replace the manifold if I want that fitting. I wish I noticed it before I installed the motor, it would have been way easier to deal with. I will see if the hole in the manifold is close to one of the pipe tap thread sizes if not I will have to turn something in a lathe and glue it in.
Thanks for the help
Old 11-06-2021, 06:39 PM   #7
Davidf
Or, cut off the fitting, Drexel/grind the fitting out of the manifold. Then tap manifold for barbed brass fitting
Davidf is offline   Reply With Quote
Old 11-07-2021, 07:42 AM   #8
95 S_Trucker
95 S_Trucker's Avatar
You can install a plug or a hose fitting into that hole. Here’s a video.
https://m.youtube.com/watch?v=eE0z4pRfHLo
95 S_Trucker is offline   Reply With Quote
Old 11-15-2021, 07:09 PM   #9
Thealien
Thealien's Avatar
He is missing the whole part that red ring is a part of. Never seen that.
Old 01-01-2022, 02:44 PM   #10
solidaxel
solidaxel's Avatar
I'm looking for a solid plug
I think you are right the red locking ring is part of the intake, BUT it does move so maby there is locking tab like the fuel line connection! !small tool!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
