Old 11-10-2021, 01:05 PM   #1
BigBird05
Yukon Radio
Does anybody else have trouble with a Yukon radio draining the battery.
BigBird05 is offline   Reply With Quote
Old 11-16-2021, 07:17 PM   #2
jocko
jocko's Avatar
Re: Yukon Radio
i have not - why are you suspecting the radio specifically?
Though not common, one thing worth checking is to make sure your underhood utility light actually shuts off when closing the hood - it won't gravity rock and click off until hood is almost shut, so you kinda gotta watch closely. Not likely the culprit, but worth checking.
Best way to chase a batt drain is with a voltage drop check as you (or hopefully an assistant) pulls individual fuses one at a time.
Old 11-17-2021, 02:21 PM   #3
S10Fan
Old Heap Driver
Re: Yukon Radio
Be sure to check the sunvisor lights as well, mine were staying on due to a bad door switch.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-17-2021, 03:35 PM   #4
BigBird05
Re: Yukon Radio
S10fan, Thanks I will do that.
Old 11-17-2021, 03:37 PM   #5
BigBird05
Re: Yukon Radio
Todays up date. While trouble shooting, the battery went bad. They replaced it under warranty. No under hood light. I will check the voltage tomorrow morning.
Old 11-18-2021, 09:20 AM   #6
hatzie
Moderator
hatzie's Avatar
Re: Yukon Radio
Bad door switches will cause the BCM to not put various higher current draw components into sleep mode.
If your replacement battery doesn't fix the problem it'd be worth paying attention to how long it takes the dome lamp to shutdown after you close the door.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-18-2021, 04:16 PM   #7
BigBird05
Re: Yukon Radio
The dome light goes out in e few minutes. When I have the hatch open the light stays on. Isn't it supposed to go out after awhile?
Old 11-19-2021, 03:17 PM   #8
hatzie
Moderator
hatzie's Avatar
Re: Yukon Radio
It's supposed to go to sleep eventually but a bunch of BCM functions stay more active til the doors, trunk, and hood are closed.
