11-16-2021, 09:33 PM | #1 |
Fuel regulator and gauge
Apparently i need to add a reg. And gauge for my sbc with edelbrock carb, whats a good looking cheaper combo or whatever that works ?
11-16-2021, 11:06 PM | #2 |
Moderator
Re: Fuel regulator and gauge
Im using a low pressure pump from summit - Fuel pump jm1003bk and a mooneyes gauge, never goes over 6 psi.
11-16-2021, 11:07 PM | #3 |
Are you running a mechanical or electric pump?
If your running a electric pump. Use a bypass regulator. It keeps the pump cooler, and running longer. They do not like dead head pumping. Which reduces their life span. If you have a mechanical either works fine. A dead head since it is cheaper to install, and a bypass if you have fuel temp issues. |
Thread Tools | |
Display Modes | |
