Old 11-17-2021, 05:12 PM   #1
Day 2 C10
solid trailing bushing?
Out of curiosity has anyone ever done as 2 piece aluminum/ steal bushing on there trailing arms ? I've utilized them in other car builds with great success I am wondering about in this application.
Day 2 C10 is offline   Reply With Quote
Old 11-17-2021, 07:05 PM   #2
SkidmoreGarage
Re: solid trailing bushing?
People use custom trailing arms with large spherical bearing rod ends to get better motion control over a polymer bushing. The arms twist under articulation, so a solid bushing will bind and cause all sorts of issues.
Besides a harsh ride, I think a solid bushing would likely cause the mounts/cross member to crack.
SkidmoreGarage is offline   Reply With Quote
Old 11-18-2021, 12:10 PM   #3
Day 2 C10
Ok great what you saying makes scene as these dont operate on a parallel axis as leaf spring do.
Old 11-19-2021, 12:45 PM   #4
SCOTI
SCOTI's Avatar
100% definitely need a joint that rotates vs anything solid @ the front mounting point of T/A's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-19-2021, 12:56 PM   #5
Day 2 C10
I'll go with tubular then I'm going for handling
Old 11-19-2021, 01:07 PM   #6
SCOTI
SCOTI's Avatar
The original beams were built the way they were for a reason.
Solid construction/tubular arms won't flex like the OE I-beam arms but will induce bind much sooner w/o a bushing that allows articulation. Make sure what you go with uses a spherical bushed style end.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2021, 01:19 PM   #7
Day 2 C10
I'll utilize a heim joint most likely as I'm used to to using them in race chassis or run the ride tech end as I have a few in stock and they work well too
Old 11-19-2021, 01:49 PM   #8
HO455
Post Whore
HO455's Avatar
Have you checked out the "Make it handle" thread?
RIP Bob Parks.
Old 11-19-2021, 01:51 PM   #9
Day 2 C10
never saw it ill look it up
Old 11-19-2021, 04:27 PM   #10
SCOTI
SCOTI's Avatar
Several companies make a spherical joint that utilizes Delrin inserts for everyday driving type of give vs a chromoly style 'race spec' joint. Ridetechs 'R' joint is similar but I don't know the sizes available. I've used Spohn.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2021, 04:34 PM   #11
HO455
Post Whore
HO455's Avatar
Best get a comfortable chair it's a long read. Well worth the time.
https://67-72chevytrucks.com/vboard/...d.php?t=419251
RIP Bob Parks.
Old 11-19-2021, 06:13 PM   #12
Big Kev-O
Big Kev-O's Avatar
Hotchkis Swivel Max Bushing Upgrade are designed for the 63-72 trailing arms(HOT21390). They cost about $200 bucks. Most people would probably just spring for complete trailing arms at that price.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 11-19-2021, 06:30 PM   #13
SCOTI
SCOTI's Avatar
Agreed.... But if someone had other mods linked to their arms, it's a way to minimize necessary changes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2021, 03:23 PM   #14
indymachinist
Food for thought....
Nascar uses I beam style trailing arns with spherical joints at the ends. They don't use square tube or anything like that. They intentionally use lighter duty arms because they WANT them to flex more for better handling.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 11-21-2021, 04:07 PM   #15
SCOTI
SCOTI's Avatar
I'm pretty sure they use the style of T/A's they use because that's what's mandated not because of any other reason.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-22-2021, 10:36 PM   #16
indymachinist
Yes and no.
-Curt
Old 11-22-2021, 10:56 PM   #17
indymachinist
https://www.jalopyjournal.com/forum/...k-arms.672544/
Good truck arm info.
As for nascar arms vs factory truck arms... if you have both in front of you, you will find the nascar versions are thinner and have a smaller cross section than the stock truck stuff. As I said before, it is because they want them to flex. So the bigger and stronger you make your tubular truck arms the more you are inadvertently getting away from what works.
I don't pull this stuff out of my butt. I've been in the racing industry for a lot of years now and spoken directly to people in the know on this suspension set up. No one needs to listen to me if they don't want to. It's not going to hurt my feelings.
-Curt
Old 11-22-2021, 11:08 PM   #18
MySons68C20
MySons68C20's Avatar
Not much to add here but my C20 arms have an extra reinforcement from the factory welded on the top section of the trailing arm. I must say it handles dang good as is!
MySons68C20 is offline   Reply With Quote
Old 11-22-2021, 11:52 PM   #19
SkidmoreGarage
That hamb thread is remarkably hostile and actually very thin on actionable information.
"More flex is more better"? If it can't be quantified, then what is the point of repeating it? I'm sure that ideal spring constant for the arms based on the vehicle weight and geometry information is available (and probably racing class specific), and I would love to see it, but without it, what is the take away? Either use stock arms or pay for someone else's R&D?
If the arms can freely twist through their range of travel, I can't imagine adding another spring/degree of freedom would net a lot of benefit without a lot of testing.
I highly recommend the"make it handle" thread on this forum. Tons of great free info for these trucks.
