Cutting Wood bed kit
A guy locally has a nice LWB wood bed kit for sale but I’m a SWB.
Can I simply cut the boards to correct length? The kit does not have any screw holes Pre drilled yet. Posted via Mobile Device |
![]() ![]() Join Date: Jan 2005
Re: Cutting Wood bed kit
Yes, they can be made to fit by cutting them down. You will need to cut both ends of the two boards that are notched for the wheel wells to keep the notches in the correct location. Dimensions can be found here:
https://gmcpauls.com/47-72_BedWood_Info.htm Last edited by pjmoreland; 11-18-2021 at 12:06 PM. |
I added this to my comment above.
You will need to cut both ends of the two boards that are notched for the wheel wells to keep the notches in the correct location. |
Thanks for this info
