Old 12-07-2021, 02:23 PM   #1
jweb
jweb's Avatar
Window run channel options
I have the Precision brand window channel seals and they leak really bad. My truck is pretty quiet with the exception of the noise I get around the windows.
Are there any better options than the Precision brand? In the photos they all look like the same corrugated/ cloth covered parts.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 12-07-2021, 10:34 PM   #2
joedoh
joedoh's Avatar
Re: Window run channel options
I am going to try steele on my next truck, lmc changed suppliers and its garbage now.
https://www.steelerubber.com/side-wi...kit-90-3288-90
thats the one piece, which it looks like what your truck has. if you have the wing window doors they make taht too.
i used to use precision windshield gaskets and switched to steele, its night and day quality difference. no more puckers, I even broke a couple windshields using harder gaskets. I can install a windshield in 20 minutes by myself with a steele gasket. never going back!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-08-2021, 12:01 AM   #3
jweb
jweb's Avatar
The Steele one is kind of expensive but I don’t mind paying if I knew it was better than the ones I have. Hopefully someone that has installed them will comment.
Old 12-08-2021, 10:17 AM   #4
nvrdone
I used Steel gaskets when I had all the glass in my '49 replaced. The installer had never used them and was very impressed. That was 3 years ago and so far no leaks, cracks or puckers. I would highly recommend them.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 12-08-2021, 11:19 AM   #5
jweb
jweb's Avatar
Wind noise is the one thing that keeps me from driving my truck long distances. I will order the Steele parts and see if there is any improvement.
Unfortunately it will be a few months before I can put them in and drive my truck. I will try to updated this once I get them in.
Old 12-08-2021, 05:10 PM   #6
edgeleycanuck
I realize I may have not inquired under the incorrect thread earlier.
I'm wondering if Russ or anyone else has an alternative for using rivets for holding the vent window vertical channel in place? Wondering about the rivet/pivot for the vent window also.
I have read some opinions on installing these rivets and it seems they can be difficult.
I believe one person cut the vent window rubber, on the inside, at the bottom pivot thus eliminating the need to remove the vent window. Anyway just curious about tips and tricks for the installing of the two kits mentioned, thanks.
edgeleycanuck is offline   Reply With Quote
Old 12-08-2021, 05:15 PM   #7
joedoh
joedoh's Avatar
i cut the rubber, i heard about the rivet problem. i made the cut on the inside, and sealed it with black urethane. the rivets in the upright track i also did not install, i glued it in
Old 12-08-2021, 06:29 PM   #8
Tempest67
Tempest67's Avatar
I cut the rubber for the vent window too.
Yes, there is a seam at the bottom, but it saves a lot of grief removing the vent window from the frame.
Tempest67 is offline   Reply With Quote
Old 12-08-2021, 07:18 PM   #9
jweb
jweb's Avatar
I haven't rebuilt any wing windows yet. I will be doing it soon on my 64 suburban.
You may want to watch this video, typically this guy does a good job of explaining the process.
https://www.youtube.com/watch?v=WiZOiHmcb_w
