Old 12-24-2021, 01:35 PM   #1
61K10
61K10's Avatar
2000 z71 5.3 code
Hi people--I have a po300 code with ck eng lt on. It only misses at idle, you can't feel it above 1000 rpm or above. I know this is a tough one as it could many different things. Have only had a bad coil in 97,000 miles. Have changed plugs and wires at 75,000. where should i start?
thanks
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-25-2021, 01:33 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: 2000 z71 5.3 code
Hi and Merry Christmas
The 0300 code refers to intermittent misfire detected by the O2 sensors....
Follow the check list in order.
Faulty spark plugs
Faulty spark plug wires
Faulty coil
Vacuum leak in intake system
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Stuck/blocked/leaking EGR valve / passages
Faulty catalytic converter(s)
Faulty camshaft position sensor
Burned exhaust valve
Defective computer
As you mentioned it only misses at idle I would be looking for a vacuum leak as a priority.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 12-27-2021, 02:59 PM   #3
61K10
61K10's Avatar
update---moved my tk for coming snow and the eng lt went off and the miss did also but came back but no eng lt.
1961 chevy K10
Old 01-04-2022, 05:31 PM   #4
61K10
61K10's Avatar
still running good no eng lt no miss?
1961 chevy K10
