01-10-2022, 04:13 PM | #1 |
Active Member
WTB: Power Steering Bracket
I'm looking for the power steering bracket circled in the attached picture (assuming this is the correct bracket for a 69 C10, 350 engine and AC).
Thanks |
01-10-2022, 09:41 PM | #2 |
Re: WTB: Power Steering Bracket
That picture is for 283/327 though 1968. Those brackets will not clear the 8 inch harmonic balancers on the 350 truck engines. These are 69-72 350 truck brackets so you will know what you are looking for. Hope this helps.
01-10-2022, 10:28 PM | #3 |
I should have one off a 70 350 a/c but I don't know if its what you are looking for.
01-11-2022, 12:26 AM | #4 |
Active Member
72BBGMC- ok then the top left bracket in this picture is the one I need?
If so then I have both brackets for the PS. Now to find the diagram in the book. Thanks |
01-11-2022, 01:09 AM | #5 |
This is the PS bracket assembled .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-11-2022, 05:30 AM | #6 | |
01-11-2022, 11:27 AM | #7 |
Active Member
Thanks everyone
