Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-27-2022, 10:31 PM   #1
HotRod4me
Winging a 1971 K5 Blazer L96 6L90 Swap
Hi, everyone. Been watching this site for a long time putting my build together in my head. Picked up a tired Hugger Orange 1971 Blazer and a parts truck over the summer.
So here were go- I love the old patina paint on the truck so I think I'm going to leave the body and paint alone for now. The drive train is a different story. I plan on doing a 2" spring lift, new stock 33" tires and a L96 motor with a 6L90 transmission behind it.[ATTACH]Attachment 2162428[/ATTACH]
HotRod4me is offline   Reply With Quote
Old 01-27-2022, 11:38 PM   #2
72gmguy
72gmguy's Avatar
Re: Winging a 1971 K5 Blazer L96 6L90 Swap
Sounds cool. I will be watching!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 01-28-2022, 09:02 AM   #3
68panelman
68panelman's Avatar
Looking good
68panelman is offline   Reply With Quote
Old 01-28-2022, 09:07 PM   #4
HotRod4me
This is going to go pretty fast for a while. I've been working on it for a little while and now just starting to post the progress to document the adventure and possible help others doing something similar along the way.
Old 01-29-2022, 12:01 AM   #5
HotRod4me
Tear down started
Old 01-29-2022, 12:13 AM   #6
HotRod4me
Motors out
Old 01-29-2022, 12:25 AM   #7
HotRod4me
Anyone looking for a motor
Old 01-29-2022, 01:01 AM   #8
HotRod4me
Parts Truck
Old 01-29-2022, 10:14 PM   #9
HotRod4me
Body is off the frame
Old 01-29-2022, 10:19 PM   #10
HotRod4me
This was a little nerving to have the body suspended in the air like this, but everything worked out in the end.
Old 01-29-2022, 10:23 PM   #11
68panelman
68panelman's Avatar
Cranking right along. I'd take that motor if you were closer. Keep up the good work!!!
Old 01-29-2022, 10:25 PM   #12
HotRod4me
Built an adjustable cart, so I could move the body around the garage if needed. Space is pretty tight!!
Old 01-29-2022, 10:30 PM   #13
HotRod4me
Talking Re: Winging a 1971 K5 Blazer L96 6L90 Swap
Ready to start striping the frame for sand blasting and paint.
Old 01-30-2022, 12:14 PM   #14
HotRod4me
Thumbs up Re: Winging a 1971 K5 Blazer L96 6L90 Swap
Picked this 6.0L L96/6L90 motor out of a 2019 Silverado 2500hd with 4 miles on it this fall.
Old 01-30-2022, 09:00 PM   #15
HotRod4me
Frame is painted and ready for assemble.
Old 01-31-2022, 09:48 PM   #16
HotRod4me
Tearing down and inspecting the NP205 Transfer case. Found some pretty good instructional videos on youtube for rebuilding this piece.
Old 02-01-2022, 10:42 PM   #17
HotRod4me
Added a Rough Country 2" suspension lift. Rebuild both axles and swapped out the open read end with the one from my parts truck into my build, since it had a stock posi rear end. Installed all new spicer u-joints to handle the additional power I'll be putting to the ground with the L96. New drums in the rear and drilled and slotted discs up front to stop this beast when it gets moving.
Old 02-02-2022, 08:20 AM   #18
jaros44sr
jaros44sr's Avatar
Looks great, nice work
Don't forget the poly mounts on.the motor, I've read where they don't play well, if you mix poly and rubber
Now would be a good time to add hydra boost, it will stop the big tires w/o.a problem, also, consider a 3 pice cross brace motor mount, if you ever have to drop your oil pan, you will be glad you did.
Now I want drill and and cross vent my front hubs, these forums are a slippery slope
Thanks for posting up, gives me hope and incentive thar someday I'll finish mine
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-02-2022, 10:44 PM   #19
Kenz72K5
Looks Good, will look in to see how your doing, My 72 K5 I purchased a year ago already had the LS1 and 6L90 but alot of things I still wanted to do such as Electric windows, door locks, 1 piece window etc. has a 6 inch lift that I would like to lower to 2-3 inch.....
Kenz72K5 is offline   Reply With Quote
Old 02-03-2022, 01:15 AM   #20
HotRod4me
Thanks for checking out my build guys. I already purchased a Dirty Dingo motor mount for that exact reason and the rubber motor mounts. Now I'm second guessing those and considering the polyurethane ones. I'm at a good point to swap them out now, so thank you again for the tip. That is exactly why I love these forums and other builders input.
Old 02-03-2022, 01:19 AM   #21
HotRod4me
Picture of the new drums and gas tank.
Old 02-05-2022, 12:13 AM   #22
HotRod4me
Transfer case rebuilt, Advanced engineering adapter installed for the 6L90 and ready to go. Now I just need to figure out a shift linkage adapter.
Old 02-05-2022, 03:34 PM   #23
HotRod4me
In tank fuel pump from Tanks Inc installed with Corvette pressure regulator and new shoes on stock rims. Love the look of these tires!!
Old 02-06-2022, 02:32 AM   #24
68ls1
68ls1's Avatar
I've got a coupe of questions about in tank pump
What part number is the one you used?
Did you have to modify depth? Tanks Inc quote max 12", where as I believe Blazer tank is around 13"
How is clearance of unit to floor, as there is not a lot of room there?
68ls1 is offline   Reply With Quote
Old 02-06-2022, 05:35 PM   #25
HotRod4me
I used the Tanks Inc PA-4 unit. The pump will flow 255 liters per hour and handle up to 630 HP with 60 psi of fuel pressure. I'm running a stock L96 motor that produces roughly 360 HP, but eliminated the mechanical fan, added a cold air intake and plan to run stainless headers with 3" exhaust. I'm guessing the little performance upgrades will add maybe 40 additional hp. The reason I went with the larger fuel pump is that I wanted to keep the option of running e85 if I wanted and e85 requires 25-35% more fuel.
Yes, I did end up extending the reach of the fuel pump arm roughly 3/4" and extended the pick/return lines, so the unit sat flat on the bottom of the tank. I also wanted to change the line to make sure I didn't have issues if I ran e85.
I'm not sure on the clearance at this point, but figured I could drop the tank down slightly if there are any issues.
Thanks for checking out my build and I'll keep you posted when I start to fit the body.
