Carpe manana
![]() ![]() Join Date: Dec 2010
Aftermarket door wedges
Curious if anyone has tried these: https://www.ss396.com/chevelle/KDW-68A.html
The brass wedges and spacer appear correct. Not sure about the striker plate.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: May 2011
Re: Aftermarket door wedges
If heard the wedges and the shims are correct but the stainless steel striker is not. I haven't tried, just going by what other people have told me.
![]() Join Date: Nov 2010
Yes I have personally used them. The brass wedges and shims fit perfect. The stainless plate however completely wrong size and holes don’t line up. Here are some comparisons I took. The larger one is the blazer/Jimmy one.
Some progress is better then no progress Last edited by Tmend; 03-08-2022 at 10:47 PM. |
Probably would still work I'm thinking? I need a set so this is good info. Thanks!
You’d have to oval out the holes to get them to screw on. Even then the there is less contact area and may result in damage. I would use the small stainless stainless plates. You check the for sale section or put up a want to buy post
Some progress is better then no progress |
Those would be very easy to make with simple tools. I had no idea there were no aftermarket available.
Carpe manana
Good deal guys. Thanks for the replies.
