Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-30-2022, 08:45 AM   #1
SuperDuperDoughnuts
Door Locks
Is the barn door lock and front door lock interchangable? Looking to get a matching lock set and was hoping to use something like this:
https://www.cjponyparts.com/lock-set...-1966/p/LDI28/
Says it's for the front doors, glove box, and ignition, but I'm hoping to use one of the front door locks on the barn door. My passenger door has no key lock, which I'm fine with.
SuperDuperDoughnuts is offline   Reply With Quote
Old 03-31-2022, 03:13 AM   #2
61ChevyPanel
Active Member
61ChevyPanel's Avatar
Re: Door Locks
My barn door lock uses the same key as my side doors & glove box. I've swapped doors on the truck so I probably just transferred the original lock cylinders. That's a pretty simple job. I would think any locksmith should be able to get all the locks keyed the same for a reasonable amount if you bring them the handles or lock cylinders.
61ChevyPanel is offline   Reply With Quote
Old 03-31-2022, 09:23 AM   #3
SuperDuperDoughnuts
Re: Door Locks
My glove box has no lock on it. I don't have the keys to the doors. I figured I could get two birds with one stone here and buy a kit like the linked one above and I'd have a common key for the ignition, glove box and doors. I don't need one on the passenger door, as it's an unkeyed door and I'm fine with keeping it that way, so I was hoping to use the one for the passenger door on the barndoor.
