03-30-2022, 03:34 PM | #1 |
Headliner Progress
After getting news about an upcoming show, I got renewed motivation to make progress with my headliner project. Although not 100% completed yet, I was able to reassemble the interior enough to feel good about entering the show (In-Progress Category, of course). I had carefully removed the original headliner and bows a few years ago, but still needed to scrub the interior metal with isopropyl alcohol so that the butyl would adhere well. This meant removing the center and rear benches to concentrate on the back four sections, and left the front bench in for driving purposes. I know a local vendor that sells the Butyl/Aluminum sound deadening sheets as well as Butyl/Felt type mats for heat insulation, so I picked up what I needed from him. With everything clean and dry, I used contact cement to fix a small spot of the factory sound deadener that had never been adhered (see second picture). I then started applying the Butyl/Aluminum sheets to the section of roof above the rear A/C (with the unit removed, obviously) and continued rolling down those sheets until the back four sections were complete.
03-30-2022, 03:40 PM | #2 |
Re: Headliner Progress
I repeated the same process with the Butyl/Felt mats, then started the repair process on the original headliner panels. Knowing that the original panels were only going in for temporary purposes (the car show and to be a pattern for my interior guy to follow), I patched holes then painted the panels an Almond color that looks real close to the color I found in some protected areas. After adding new dome lights (one for each bench), I installed the panels using only the metal portion of the bows to hold them up better than nothing at all. As the plastic portion of the bows are very brittle, I didn't want to snap them in place just to have to remove them again...so I was fine with this level of completeness. With the back four sections complete, I removed the front bench and installed the three layers (silver/black/headliner) onto the factory sound deadener that is found only over the front seats of Suburbans. The last section of headliner has a small (but very stiff) warped section (see second to last picture) that the metal bow would not confine, so that edge is below the bow. The sound deadening/heat insulation results are terrific...and the headliner doesn't look horrible, so I'm okay with it if it takes a while to move on to the next step. The last picture is "somewhat" close to how I imagine the new "Beach-Burban" headliner will look...but that will be more dependent on how my interior guy needs to proceed.
Woody |
03-30-2022, 05:45 PM | #3 |
That looks really good! I did the same with the butyl sound deadener/insulation, then on the panel side, I added a 1/2" of regular seat foam and sandwiched it between the panel and butyl. I had some stainless strips made to do away with the factory plastic pieces that clip on. I shaped the strips by hand, and drilled 5 holes to hold the stainless strips up and it looks pretty good, and I won't have to worry about the plastic getting brittle and breaking like some of mine have. Here I have the rear stainless strip on, and the others still waiting to be done.
03-31-2022, 11:41 AM | #4 | |
Woody |
03-31-2022, 05:59 PM | #5 |
This foam-backed headliner material I found on Amazon. Looks and feels good. Used 3M Super 90 spray adhesive to attach it to the panels.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-03-2022, 11:49 AM | #6 | |
Woody |
04-03-2022, 01:07 PM | #7 |
Post Whore
That really turned out nice. Headliners are such a difficult are area to make look good without spending thousands of dollars.
What did you do to restore the original panels to such a nice glossy look? Can you post some more information on the felt pieces? Those may be what I've been looking for to use behind the side panels in the back of mine. Pontiacvince yours came out great too! Great work gentlemen!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-03-2022, 01:48 PM | #8 | |
04-03-2022, 02:12 PM | #9 | |
The black Heat Insulation mats are approximately 15" x 11" x 3/8" and are butyl backed. I believe Jerry said that it was made or used by Ford, but I'm not positive on that? I'm including a picture of Jerry's business card so you can call him if you want to? When I bought my silver sound deadener from him, he didn't have any of the black heat mat with him, so he shipped it to me. He's a nice guy and has been selling these products locally for a very long time. He has other products that could work for you as well, but I liked this one, and he discounted the price by about 50% since the first time I talked to him a few years ago (he said he wanted to move some of his inventory)...so it might be good timing? I hope this helps, but feel free to ask for more clarification or anything else if need be. Woody |
04-03-2022, 02:19 PM | #10 | |
Woody |
04-03-2022, 03:41 PM | #11 |
Post Whore
Thanks for the quick reply. I will look him up.
And as a side note I did my headliner with FRP. I did not need to heat it to get it to conform to the curves needed. But I'm not a expert, at anything really.
04-03-2022, 04:36 PM | #12 | |
Woody |
04-04-2022, 12:18 PM | #13 |
Post Whore
PM sent.
04-04-2022, 12:38 PM | #14 |
