Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 04-20-2022, 06:02 PM   #1
elorenzof
Factory AC Stuff
Just removed from a 1970 c10. everything in the picture. no compressor (bad) no condenser and receiver drier (all very bad)
THE ONLY issue: where the vacuum canister mounts to the evaporator box, it was starting to tear the box where it bolts to the box if that makes sense.
Included but not picture is also in very good shape no cuts or splices a/c - heater wiring harness.
Arizona truck, everything is in pretty good shape.
elorenzof is offline   Reply With Quote
Old 04-26-2022, 06:31 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Factory AC Stuff
Not sure about value but I can tell you I gave $200 for what you have pictured and I found it on Craigslist last year. I think I got a pretty good deal on it for everything that was there. That being said I have also seen the outside the firewall box go for $150 by itself, controls go for $50 on up depending on condition, and inside boxes for $100. I hope this helps,
Carl
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
