Old 04-26-2022, 03:07 AM   #1
Spicer
Junior Member
Spicer's Avatar
V2500 1990 Suburban
Specs:
502 RamJet.
TH400 (manual VB) NP205
twin stick, Dana 60 with 4.56
alloy 35 spline shafts E-Locker
35 Spline Spicers, 14 FF Daully
housing, 4.56 Detroit, rear disc,
rear sway bar, Bilstine Shocks,
limiting straps, rear frame
runners, 6" front & rear springs,
2" body, dual Batteries, ASM
58MM TB, Sanderson headers,
Flowmasters series 40 stainless,
front & rear stainless axle
truss's, factory Tach, 35
Boggers (Load Range E) 16.5 X
14 Weld Typhoons, CUCV frame
brackets, T-case to Bellhousing
brace, scatter shield, deep pan,
4.5 rear shaft.
Spicer is offline   Reply With Quote
Old 04-28-2022, 04:42 AM   #2
LT7A
Re: V2500 1990 Suburban
That's a lot of truck! Even after reading the list, I wasn't quite prepared for the picture. Very clean, very nice rig.
Old 04-29-2022, 10:50 PM   #3
elimontfort
elimontfort's Avatar
That thing is nice
elimontfort is offline   Reply With Quote
Old 04-30-2022, 01:14 AM   #4
Spicer
Junior Member
Spicer's Avatar
Thanks!
Result is 38 years and what started out as a daily driver and ended up a project rig… you’re right allot of truck, to much for a sit in the front yard rig…
Old 04-30-2022, 01:17 AM   #5
Spicer
Junior Member
Spicer's Avatar
Originally Posted by elimontfort View Post
That thing is nice
Thanks! Picture turned out nice, Iphone to the rescue…
Old 04-30-2022, 01:19 AM   #6
Spicer
Junior Member
Spicer's Avatar
Old 04-30-2022, 01:21 AM   #7
Spicer
Junior Member
Spicer's Avatar
It started out as the Bondo bandit in 1983!
