Old 05-05-2022, 07:40 PM   #1
DNGR
DNGR's Avatar
67 C10. 3/5 drop question
My Truck has a CPP 3/5 spring drop. Next, I want to do the 2.5 drop spindles with the disc conversion. My question is will I need to change the. Rear springs to make the truck level?
67 C10 Step Side
Upgrades:
American wiring, CPP Tubular Control arms
CPP Sway ,CPP Pan hard Bar
Cowl Hood, Rear mounted Fuel
Power Steering, Classic Dash
DNGR is offline   Reply With Quote
Old 05-05-2022, 07:45 PM   #2
SkidmoreGarage
Re: 67 C10. 3/5 drop question
There are a lot of variables here, to say what you need for certain. However, you likely won't need to replace the springs. You could do an axle drop to level it out, just figure out how much you need and buy it. When you get to 7" of drop, there isn't much travel left, FYI.
SkidmoreGarage is offline   Reply With Quote
Old 05-05-2022, 10:46 PM   #3
Mike C
Mike C's Avatar
On a coil spring truck it’s easier to get a little more drop using blocks. That’s what I would do. My leaf truck is dropped 4.5” in front and 7” in the rear with no C-notch. Once you do the front, decide how much lower you want to go in the rear and just buy the appropriate block.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-06-2022, 07:50 AM   #4
DNGR
DNGR's Avatar
Thank you guys for the helpful info!!
67 C10 Step Side
Upgrades:
Old 05-06-2022, 08:03 AM   #5
SCOTI
SCOTI's Avatar
Good suggestions.
I'll add, drop blocks are an easy way to get additional drop. But there are consequences if getting aggressive. Drop blocks beyond 1" in height can put the rear axle scrub-line below the wheel lip if using 15" wheels. In the event of a serious tire failure, the U-bolt ends can make contact w/the road surface. Like dropping an anchor, it's not a big deal if moving unless it catches something or digs in. Wheels w/a larger diameter change the scrub-line dimension offering more wiggle room for a taller block w/o the possible contact concern.
This is just something to be fully aware of when it comes to different lowering methods.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-06-2022, 10:12 AM   #6
DNGR
DNGR's Avatar
Originally Posted by SCOTI View Post
Good suggestions.
Thank you, So a larger wheel may help as I go lower.
67 C10 Step Side
Upgrades:
Old 05-06-2022, 10:19 AM   #7
68 P.O.S.
Is it level with the current 3/5 drop?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-06-2022, 10:27 AM   #8
DNGR
DNGR's Avatar
Good question, I need to measure but Also I was waiting for the front end to settle. It doesn't have 20 miles on it since I did the front end.
67 C10 Step Side
Upgrades:
Old 05-06-2022, 11:57 AM   #9
SCOTI
SCOTI's Avatar
Yes (when using lowering blocks =/>2").
If a 15" tire goes flat but stays on the wheel w/1.5" blocks, it will still roll depending on the thread extended after the nut under the arm that secures the axle tube. It will also likely make some contact & damage the threads @ the end.
Beyond that 1.5", those U-bolt ends are making contact. Larger diameter wheels simply increase the scrub-line dimension allowing use of taller blocks w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
