05-12-2022, 02:08 PM | #1 |
Truck Bed Tie Down Options?
72
Looking for a fold down tie down insert for bed side or D ring type that would use one of the truck bed bolts to anchor. ideas appreciated |
05-12-2022, 04:07 PM | #2 |
Re: Truck Bed Tie Down Options?
I drilled about 1/2" hole into the side of the rear stake pocket, enough to slip in a tie down hook.
there is already a large hole in the bottom of the front stake hole, good to attach tiedown hooks. |
05-24-2022, 09:48 PM | #3 |
Not a bad nut after all..
Bull Ring 4098 fits the rear two stake pocket locations in '67-'72.
I'm happy with mine. Only minor complaint is I can hear them rattle slightly when retracted when I have the sliding rear window open.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
05-25-2022, 10:15 AM | #4 |
^^, those are what I have as a placeholder...did see a C10 with D hooks on a 2 bolt strap mounted on inside of bed, top, where rail slots are that also looked discrete but require drilling holes. Have not found Stainless ones, just zinc coated
05-25-2022, 04:04 PM | #5 |
70+ ( Old Skool Club )
Did you try them in the centre and front holes as well. Listing on go to 88 model year on their website.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-25-2022, 04:43 PM | #6 |
Maybe not what you need but I replaced four bed bolts with "I" bolts to serve as tie down points. Just in the front of the wheel wells. Then I had a cargo net that held down the cooler and lawn chairs.
See pic. |
05-25-2022, 05:20 PM | #7 |
^^^, considered that also but using single bolt D rings so they would lay flat
Like your bed, mine is "done" so I am not hauling anything other than coolers, boxed merchandise so a single bolt held something would work just need to find stainless vs "metal" (zinc) type |
05-26-2022, 08:18 AM | #8 |
They don't fit these locations on '67-'72 (opening is the same, but there isn't enough room below the opening to install).
05-26-2022, 11:16 AM | #9 |
I posted the ones I used last year. Pictures are sideways but they work really well, I have had some serious load on them with no bed or anchor distortion. Not exactly a direct fit but not difficult to make work either.
https://67-72chevytrucks.com/vboard/...d.php?t=823196
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
