![]() Join Date: Mar 2006
solution that make fender bolts look new
I had a gallon of this solution about 15 years ago that when I cleans say the fender bolts and bolts under the hood made the bolts look like they did from the factory. does anyone where to get this solution? thanks Rick
Its a Truck Thing......
Re: solution that make fender bolts look new
I don't know what brand you are asking about, but try full strength simple green and let them soak. Does really good on metal and bolts if they are not too far gone.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
This was a clear solution that came in a gallon bottle and once you had cleaned the bolts you put them in this solution and it made the black like the original bolts
found out its black oxide
I need to look at that stuff. Simple Green will take it down to bare metal and it really looks clean.
Smitty
Black oxide is not that tough. It is basically colored rust.
Here is a brief rundown on the process https://www.anoplate.com/news-and-ev...ide-it-can-be/ |
![]() Join Date: Aug 2005
Eastwood used to sell that stuff, maybe they still do. Black oxide coating.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
I had a jug of something that turns rust to black oxide. I think I still have it. I'll go look. The name keeps trying to come to me but my mind won't allow it in
You can buy a pack of 25 on amazon for <$15. I bought a pack of them and the mating speednuts due to the amount of breakage on my rusty junk.
https://www.amazon.com/16-18-Body-Bo...s%2C106&sr=8-9 |
#10 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
You know how original bolts get. Not exactly rusty, they just have a bit of some rust on them. They look dirty, used, not good enough to put up against fresh work. I have always saved original hardware when removing parts. I'd rather keep my trucks and Harleys original as I can by simply dumping a can of bolts in a solution, let soak a while, hose of, and let dry. It's easier than making a list and ordering for me. You can use a gallon of solution for a multitude of rust removal, including body parts. I'd imagine buying all those bolts would cost more than a jug of ... HEY!! I think I remember the name. Was it Ospho?
Yep https://cdn.shopify.com/s/files/1/12...g?v=1645706736 That stuff worked really well I had this stuff somebody gave me and he didn't know where he got it. It was clear. I never could find it sold anywhere. I had removed a sliding rear window and the window flange on the cab was pitty rusted on the lower sides, corners, and across the bottom. I brushed that stuff on there and it turned it into fresh metal color, every nook and cranny.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-20-2022 at 09:32 AM. |
if you decide to use Ospho read this thread before buying it . it's a process not just soak and go .
![]() http://www.spiuserforum.com/index.ph...ze-ospho.3973/
#13 | |
![]() Join Date: Jul 2015
Caswell plating is the company you most likely would be looking for. |
#14 |
![]() Join Date: Oct 2016
I think Evaporust leaves a fairly dark phosphate looking coating.
__________________ '68 K10 496/465/205 |
#15 |
![]() Join Date: Mar 2011
X2 been down that road Im with Grumpy.....buy them
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#16 |
#17 | |
![]() Join Date: Dec 2009
![]() That's the bolt I have been looking for ![]() ![]() Is this your Go to for bolts and brackets?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#18 | |
#19 | |
That the way it works . Cause when you find the one ![]() You quit looking ![]()
#20 | |
The only hardware I paint is the bolts that get body paint on them. You should prep new bolts for paint as well. I also think that guy makes a bigger deal than it actually is. Overkill is being safe for sure. I've never seen any problems with paint after using Ospho. When I store the hardware after Ospho I spray with mineral oil to prevent rust flashing back. I guess I never searched that Auto Tech Rust Prep. I found it online, even the same label after 20 or so years. They improved the spray head. Mine's pump spray and it stopped spraying. It's not clear. This stuff made rusty metal fresh raw metal color
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-21-2022 at 08:44 AM. |
#21 |
![]() Join Date: Oct 2014
I use EvapoRust for my seat tracks and all the hardware. I let everything soak overnight, sometimes longer. When I get them out of the bucket, I rinse with water a blow dry them with the air compressor. The bolts then go into a cup of oil. The seat tracks I do repaint.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#22 |
I use an old crockpot filled with apple cider vinegar. Works great on all rusty parts that are no longer in the local junk yard. Then just primer and paint.
#23 |
![]() Join Date: Feb 2009
White vinegar will remove the rust and what's left of the coating or plating. I follow that up with a baking soda bath. It's tedious, because you have to wire brush them down to clean metal.
Caldwell's cold black oxide & sealant makes them sharp, but I only used that sparingly for parts I hadn't had zinc plated. They'll look bad unless they're completely down to metal with no sign of rust or pitting. As Grumpy said the black oxide (cold) is not so corrosion resistant, you'd be wasting your time in a rust prone climate.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-24-2022 at 02:43 AM. |
