![]() ![]() Join Date: Jan 2002
Found washer in rear axle
Changed the seals in rear axle put shafts back in and found this washer lying in the bottom of the axle don't no where it goes.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
![]() Join Date: Oct 2009
Re: Found washer in rear axle
I think it’s a spider gear thrust washer - believe it goes between a spider gear and case. Might check the others that aren’t missing a washer to confirm location and orientation.
![]() Join Date: Apr 2012
Agree. That goes behind the spider gears. When you had the diff pin out did you spin an axle? If so the washer could have slipped out.
Thanks I will check it out.
![]() Join Date: Mar 2015
Happens all the time. The confusing part is some differentials require them and other do not.
Got it back in thanks for everones help.
Great. Good thing you found it or you may have had a bad day on the road!
