05-22-2022, 10:45 AM | #1 |
Parts help needed
Hi, I was wondering if someone could help me locate a part.
I'm looking for the bushing that holds fresh air inlet door into cab under cowl. I have looked at many part suppliers with little to no luck. Images below show picture of white bushing under cowl. Thanks |
05-26-2022, 04:13 PM | #2 |
Re: Parts help needed
Hey Brother! I keep those in a jar next to the hen's teeth
Seriously, they are hard to find and no one makes them in the aftermarket world. I know, been there - done that! You would have better luck posting a WTB parts section. That's how I found the one for my truck. Another possibility is if you have access to a 3D printer or know someone who does, you might be able to make one. Better yet, make a bunch of them and sell them. One snag there is you have to have one to make them. I have one I would LEND to you for the 3D process. If you are successful all I ask is the return of the one I lend you and a couple of the finished product. Good luck in the hunt. Randy |
05-26-2022, 11:45 PM | #3 |
I bought one in a used parts assembly from a guy, and it was almost toast, so I fired up the lathe and made one. They are simple to make.
05-27-2022, 01:20 AM | #4 |
Lathe nothin; for those of us without lathes and in need of a small part like that, I'd go to the junkyard and find a slightly larger piece of plastic and simply make one using an angle grinder. It'd be crude but it'd be made of newer plastic and probably work fine.
05-27-2022, 07:42 PM | #5 |
If someone could draw it up, I could easily print one.
05-28-2022, 02:21 AM | #6 |
I have an entire stock AC system from a 1970 C10. Ill go through the box tomorrow and see what I can find.
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
05-28-2022, 06:30 AM | #7 |
I also have some. If you don’t have any luck send me a PM and I will get you hooked up. Don
05-28-2022, 09:11 AM | #8 |
Are you talking about the white piece?
Make a drawing with the dimensions (you can just draw it by hand) and post it here.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations Last edited by May70; 05-28-2022 at 09:33 AM. |
06-05-2022, 08:56 PM | #9 |
Seriously, they are hard to find and no one makes them in the aftermarket world. I know, been there - done that! You would have better luck posting a WTB parts section. That's how I found the one for my truck. Another possibility is if you have access to a 3D printer or know someone who does, you might be able to make one. Better yet, make a bunch of them and sell them. One snag there is you have to have one to make them. I have one I would LEND to you for the 3D process. If you are successful all I ask is the return of the one I lend you and a couple of the finished product. Good luck in the hunt. Randy ____________________________________________________________________________________________________ _____ Thanks for your help. If you could please send me pictures and possibly outside diameter of part as my son has a 3D printer. Thanks |
06-05-2022, 09:41 PM | #10 | |
I have a 3d printer.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
