05-23-2022, 09:52 AM | #1 |
Are "Heavy Duty" Clutches Overkill?
Looking to put a new clutch in my '72 C20 with the stock 402 mill. I originally had a Borg & Beck lever style years ago and yanked that stiff POS in favor of a diaphragm style 12". Are to "HD" diaphragm versions that much harder to push? Are they more prone to chatter? Just stick with the stock spec one?
Thanx! Bud |
05-23-2022, 10:14 AM | #2 |
Re: Are "Heavy Duty" Clutches Overkill?
Diaphragm are much easier to push and have the same amount of clamping force as the borg/beck style. Much easier on the linkage and your knee
05-23-2022, 10:41 AM | #3 |
This was my experience w/them as well w/the caveat being a higher end diaphragm vs. lower tier cheap stuff.
05-23-2022, 10:56 AM | #4 |
Thanx!
05-23-2022, 03:06 PM | #5 |
Post Whore
Are you doing anything with the truck that would abuse a regular clutch? Any towing, heavy loads, off roading? If not then I would use a quality factory replacement clutch.
Are you currently having clutch chatter problems?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-23-2022, 06:17 PM | #6 |
If getting a full-face organic material disc, you won't have chatter. Puc type disc material (ceramic, Kevlar, etc) are more aggressive to hold more power and clutch dumps but are prone to chatter.
Replacement OEM type diaphragm clutches from companies like Valeo, LUK, etc will be fine |
05-23-2022, 11:57 PM | #7 | |
I just bought a Luk clutch kit and I will see how it goes. |
05-24-2022, 01:42 AM | #8 |
I second the Luk clutch kit.
Used and rebuild are junk. Luk seems to the only reliable clutch manufacture left. |
05-25-2022, 03:00 AM | #9 |
Good Luk! ; )
Let us know if you like it. |
