05-28-2022, 01:01 AM | #1 |
spark plug wires
Would like to see some pictures how you did your plug wires dealing with headers. ( you routed yours wires)
05-28-2022, 08:31 AM | #2 |
Re: spark plug wires
Just like on a corvette.
Down behind the heads, along the pan rail and up to the plugs. Use adel clamps or cable ties to secure them. |
05-28-2022, 08:44 AM | #3 |
Ok, stupid question of the DAY. What is a Adel clamp?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-28-2022, 09:09 AM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Dont feel bad, I didnt know what these were called either
https://www.anhosefittings.com/adel-...nt=Catch%20All
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-28-2022, 09:28 AM | #5 |
These work great.
Link:https://www.summitracing.com/parts/spe-18483 Another option. Link: https://www.summitracing.com/parts/tay-42504 I use something like these for spark plug wires. Link:https://www.summitracing.com/parts/a...make/chevrolet Another idea is to use an individual boot the the one that are the closest to the header. Link: https://www.summitracing.com/parts/pnx-8563ht-1 Just for ideas Hope this helps.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-28-2022, 11:12 AM | #6 |
05-28-2022, 11:47 AM | #7 |
There are OTVC and UNTVC (over or under valve cover) SBC wire sets, All require some form of wire holders typically attached to the valve cover bolts for OTVC and tap block or head holes for under. Wire routing is a personal choice. I have over on one car and under on another, both with headers. The typical part sources like Summit, etc. have many wire holders to chose from so browse away
over |
05-29-2022, 06:53 AM | #8 | |
05-29-2022, 01:39 PM | #9 |
Here's what I did, cheap but still clean looking. I used a universal wire set so I could trim to length, and some Mr Gasket brackets and clips.
05-29-2022, 09:58 PM | #10 |
Having done this a bunch of times, the best method by far with headers or rams horns is from underneath. If you have log type manifolds then over the valve covers works better. The Corvette wires are the way to go. ‘73 if points style distributor and ‘75 if HEI.
05-29-2022, 11:45 PM | #11 | |
The Adel clamps are often seen in aircraft use. A metal band held in place with a screw of some sort and a rubber cushion between the band and what you are holding.
05-30-2022, 08:06 AM | #12 |
L6 or V8?
This is a Pertronix set up. Before I went HEi.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-31-2022 at 06:06 PM. |
05-30-2022, 08:19 AM | #13 | |
Of course, on an L6, the headers are on the opposite side...
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-31-2022 at 06:05 PM. |
05-31-2022, 01:06 PM | #14 |
I went above and separated them like a factory small block would have been done in 1968 in like a Chevelle or Camaro. I used the factory 4 wire stand on the upper end on a intake bolt. The driver side has a larger bracket with a hole in it for the power brake hose as well as a throttle return spring hook. The the the 2 wire clips on the lower valve cover bolts.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
05-31-2022, 05:47 PM | #15 |
Here's my 350 in a '71 GMC Jimmy:
I used that ''ladder'' plug wire separator. Also hi-heat socks on the plug boots. Old pic showing the ''Mummy wrap'' on the headers. I thought I'd get away with it due to AZ's low humidity. No such luck. In 7 years, my Heddman Hedders had rusted thru. Using a wrap voided the lifetime warranty. Even though I was careful to get the exact same part number on the headers -- for ease of replacement -- I got boned because Heddman had ''improved'' the design with a Ball-mount collector, not the familar 3-bolt direct collector/exhaust pipe. Real PIA to sawzall thru old pipes, and then run 7 miles down the main drag to get to a Midas where they could weld on a connection. All the while sounding like a B-25 taxiing.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-31-2022 at 06:00 PM. |
05-31-2022, 06:13 PM | #16 |
Here's how I did mine
06-03-2022, 01:02 PM | #17 |
If you've got newer heads with the small threaded holes on the sides, you can use spark plug wire retainers from 96-99 trucks. I had to trim mine a little to clear the headers. One of the retainers doubles as the dipstick mount, but that can be trimmed off if not needed. I also used a set of retainers from an 80s van that attach to the rear of each head.
06-04-2022, 01:52 AM | #18 |
76 Vette wires.
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-04-2022, 07:15 PM | #19 | |
06-04-2022, 07:41 PM | #20 | |
06-04-2022, 09:15 PM | #21 |
My Jimmy has the Carter AFB 9635S which is essentially the same as a 1405 [600 CFM] and Heddman 69210 Hedders.
Stepside has a 1404 [500 CFM] as Carters were unavailable in 2003, and Clifford long tube headers. Was your truck originallly Orange?
06-04-2022, 09:19 PM | #22 |
It was originally orange. It was resprayed about 25 years ago. The paint under the original tar insulation on the cab floor is orange.
06-05-2022, 05:57 AM | #23 |
I've noticed Zinc Chromate primer under the top paint on the grille.
06-05-2022, 03:05 PM | #24 |
I was planning to use Taylor wires but my cousin talked me into MSD Corvette wires. I ran them down under and back up to the plugs but for some reason one wire #5? would not reach. I ended using a replacement wire from another set on that plug, same size wire just not MSD. We checked my cousins truck and he had made some type of weird adapter to make his reach. The adapter consisted of a nail and some rubber hose, it looked really cheesy and he offered to make one for me but I said no thanks, lol.
06-05-2022, 08:09 PM | #25 | |
