![]() Join Date: Mar 2011
what would you do?
im going to paint my inner front fenders same color as truck should I attach the fasteners to the inner fenders and paint them truck color or leave them black with the chance of scratching the inner fenders as I attach them ...............................am I answering my own question
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Re: what would you do?
The speednuts attach to the outer fender, not the inner
![]() Join Date: Oct 2020
Paint them and avoid the rust issue later.
They will scratch the paint ,but if you spread them open with 2 small screw drivers, they should slide over the sheet metal better
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
thanks all... im going to paint them spread them attach and paint again
#6 | ||
"I ain't nobody, dork."
You asked what would I do?
I would paint the inner fenders factory black. ![]() And like mentioned above... the nuts clip on the fender lip, not the inner fender. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
I would totally abandon what you are talking about doing.
1) No part of or near the nut is visible when assembled. 2) I would not spread the clips. These things are a real pain if they don't grip properly. They are made of spring steel. What I would do: Have some help and lots of masking tape as you install the inner fender to keep from scratching what does show. This includes the inner fender, the outer fender, the bolts, etc. |
