06-01-2022, 10:01 PM | #1 |
Sticky steering wheel
When humidity is up (always in Kansas) my 68 steering wheel gets sticky and leaves my hands black. Anybody have luck with cleaning or possible clear coating? Is there a paint for this issue? Thanks in advance.
06-02-2022, 12:41 AM | #2 |
Re: Sticky steering wheel
'67/'68 Steering Wheels were made of a composition of clay/ glue and ground walnut shells.
[Or something like that...] The same stuff the first generation skateboard wheels were made of. '69 and later wheels are made of Cycolac, a plastic. I used to know some surfers who rubbed surfboard wax onto the wheel, but on hot days, then the wax gets sticky too. You could wrap the wheel [like bicycle handlebars] or wear gloves.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-02-2022 at 06:45 PM. |
06-02-2022, 01:03 AM | #3 |
Xtra large lace on cover works well. I haven't found anything to clean 'm .
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
06-02-2022, 08:53 AM | #4 |
denatured alcohol will remove the oils/stickiness
06-02-2022, 10:04 AM | #5 |
Living in the flatlands of Kansas humidity is nearly always a problem and I have always wrapped my vehicle steering wheels with a lace on wrap. Works well and when they do get a bit grimy and dirty I wipe them down using MeGuiar's vinyl treatment. Does a good job cleaning and removing the crud, just the nature of older steering wheels as the material used breaks down.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
