Old 06-05-2022, 10:21 PM   #1
lutronjim
? for Entropy radiators
I have a Entropy radiator for my LS/LC9 in my 70. The overflow fitting has machine treads instead of pipe threads.
My ? is how has anyone sealed the overflow fitting to the radiator. I used many layers of silicon plumers tape. This only last a few months before it breaks down and then no suction-no refill.
I also tried form-a-gasket but the antifreeze seems to not let it cure.
Any suggestion would be appreciated.
lutronjim is offline   Reply With Quote
Old 06-05-2022, 10:37 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: ? for Entropy radiators
If you have the correct thread fitting, use something like Permatex Indian Head sealer. You'll be cussing when it's time to take that fitting out, though.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-06-2022, 12:40 AM   #3
geezer#99
geezer#99's Avatar
Can’t you just drill it out and rethread it.
geezer#99 is online now   Reply With Quote
Old 06-06-2022, 02:03 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What did Entropy suggest?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-06-2022, 03:56 PM   #5
typerr
It might take an o-ring fitting like you see on surge tanks. Not to be a smart ass but I'd call Entropy and ask....
typerr is offline   Reply With Quote
Old 06-06-2022, 09:47 PM   #6
lutronjim
retap voids warenty
Entropy said silicon tape but it doesn't last.
Tomorrow I will take a look and see if an O ring might work
Old 06-06-2022, 09:55 PM   #7
geezer#99
geezer#99's Avatar
I searched and found several different machine thread barbs but not sure what you need.
You got a quick pic of it plus size?
Old 06-07-2022, 07:34 AM   #8
Joyridin
I use this stuff. BBC engines require thread sealer on the head bolts as the bolts go into water jackets. I have never had a problem.
https://www.permatex.com/products/th...ith-ptfe-4-oz/
Joyridin is offline   Reply With Quote
Old 06-07-2022, 09:15 AM   #9
geezer#99
geezer#99's Avatar
A further search found this.
Are you sure the barb isn’t 1/8 inch npt. The threads on them look a lot like machine threads.
https://www.stevesnovasite.com/threa...nipple.680827/
Old 06-07-2022, 09:36 PM   #10
lutronjim
1/8 npt wont fit
The barb fitting is what came with radiator
Thanks to typerr's suggestion - I took a closer look at neck and found a flat boss where its drilled and tapped. This will enable the use of an oring.
Thanks to all
