Old 06-06-2022, 08:48 AM   #1
7tee
7tee's Avatar
A/C STV valve test...
Does anyone here know how to bench pressure test an A/C STV valve or the procedure, thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 06-06-2022, 12:26 PM   #2
Mnguy
Re: A/C STV valve test...
There really isn't a reliable bench test, other that to pressure up to test for leaks. You diagnose them with the system running to check pressure and temperature differentials.
Mnguy is offline   Reply With Quote
Old 06-06-2022, 05:41 PM   #3
7tee
7tee's Avatar
So all you can do is replace the piston diaphragm and hope for the best, does that sound right? Thanks...
2010 Acura RL...
Old 06-07-2022, 11:41 PM   #4
Richard
Had to do a search for the term "STV valve", never heard it before. In the 67-72 trucks there is a POA valve. Seems to be similar. Here is a post on adjusting a POA http://67-72chevytrucks.com/vboard/s...&highlight=POA may help?
The other valve in the system is the TXV. Do not recommend adjusting the TXV. Which one are you referring to?
Richard
