Post Whore
![]() Join Date: Aug 2014
Where to get Control Arm Seals?
I need both the upper and lower control arm rubber seals for my 1971 C10 2WD just the rubber seals. From what I have seen is places like Rock Auto want to sell you the whole kit with the shaft and the metal cups that screw in to either side. Your help is greatly appreciated
here's a link to MOOG upper https://www.moog-suspension-parts.com/moog-k6098 and here's MOOG lower https://www.moog-suspension-parts.com/moog-k6147 Last edited by Gregski; 06-22-2022 at 11:43 AM. |
Post Whore
Re: Where to get Control Arm Seals?
Closest thing I found so far for the lower control arm bushings is this from Classic Parts but cups included:
https://www.classicparts.com/1963-72...ctinfo/74-323/ but they want $15 bucks each so that's $60 plus dollars for four of them and it's on 3 Week Back Order Last edited by Gregski; 06-22-2022 at 11:44 AM. |
Post Whore
Re: Where to get Control Arm Bushings?
LMC claims to have just the rubber seals for the upper control arms but their listing states: 2 WHEEL DRIVE 3/4 TON 67-72
https://www.lmctruck.com/1967-72-che...-2-wheel-drive Last edited by Gregski; 06-22-2022 at 11:41 AM. |
![]() Join Date: Dec 2013
Just spend the $60. and buy them ,Think of it this way with all the cash you have falling out of your pockets from not buying $7.00 a gallon gas for your electric truck you'll be way ahead !
![]() Sorry , I had too ! ![]() ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I don't see an easy way out here. Moog kits with the cross shafts and bushings are just over $30 on RockAuto so it's the same price but you get the cross shaft as well.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
I just replaced shafts and bushings, IMHO the way to go
Post Whore
thanks, what rubber friendly grease do you recommend to make these go on easier and prevent them from squeaking later?
The bushing material is a rubber like (not polly) so I just use regular grease I lube all my zerk fitting stuff with that is not poly.
Green grease would also be fine is you are concerned about Petro based grease. Sold at most auto part stores. I use green grease on my poly suspension stuff on other cars |
#9 | |
lmao
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
![]() ![]() Join Date: Jan 2005
Is this possibly what you are looking for? The description reads right, but the photo looks like the upper seal.
https://www.classicparts.com/mobile/...ctinfo/74-324/ |
![]() ![]() ![]() Join Date: Jan 2018
The rubber pieces in the 63-72 control arm shafts are not bushings. They are just for keeping dust and dirt out of the threads. The steel caps that screw on to the shaft is doing the "bushing" activity. Use plenty of the grease that you would use on your steering joints.
The swuarebody control arm shafts do use a rubber bushing, but the shaft is different than the older ones to account for the rubber bushing.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#12 | |
Post Whore
well they claim this indeed is the lower control arm seal and it's just a new look/design so we shall see Last edited by Gregski; 06-16-2022 at 12:42 PM. |
#13 |
Post Whore
ok I think these are the right upper control arm seals
https://www.classicparts.com/1963-72...ctinfo/74-308/ Last edited by Gregski; 06-16-2022 at 12:37 PM. |
#14 |
Post Whore
so both upper and lower control arm seals showed up today from Classic Parts and they seem hefty and pretty nice, we shall see how they fits
#15 |
Post Whore
and here's how the Classic Parts uppers compare to the flimzy junk LMC tries to pass on as their uppers
#16 |
Wow huge difference. Post pics of where they actually go too and how they fit will ya?
#17 | |
Post Whore
https://67-72chevytrucks.com/vboard/...826089&page=17 |
#18 |
Just to be clear, what I am seeing in your photos are not bushings. They are dust sheilds/seals for the bushing and cross shaft. The actual bushing is the large metal piece that looks like a nut on both ends of the cross shaft.
#19 |
Post Whore
now I'm just showing off, but these are not new, I cleaned and powder coated these
#20 |
Post Whore
yes, sorry, you are 100% correct! I come from the Squarebody world, please forgive me
#21 |
No worries. Just didn’t want you to have some misplaced expectations if your bushing have slack in them.
#22 | |
Thanks Gregski for the photos. I see now lookin at my truck I need those as well as I do not see them.
#23 | |
Post Whore
#24 |
Post Whore
Oh wow! in that case I would highly recommend you give them zirc fittings a shot of grease pronto just to be sure there is still some in them cups, until you get around to putting the rubbers back on, assuming you are driving that rig around still
#25 |
I am driving it yes. I just greased them Sunday. I got the truck just over three years ago and have been drivin it for just over two years now. Thanks to everyone on here I have learned a lot about my truck in a hurry. I was a grease monkey for 30yrs so I knew how to do the work but what goes where correctly and all the cool tips tricks and hints along with how toos really made workin on my truck easier and enjoyable. I gotta take it to get aligned and according to how that goes will decide if I change them now or later. Thanks again
