06-19-2022, 12:51 PM | #1 |
Casting numbers
I just checked my block casting number and its 3837004 I looked it up and they are 56 numbers one one site and 55-57 numbers on another. My truck is a 59. Is there any difference I should know about between my 59 and the earlier numbers? Will the parts on both motors interchange or were there changes from year to year?
06-21-2022, 09:46 AM | #2 |
Re: Casting numbers
3837004 was used from 55-57, 235ci.
Shouldn't be any issue with using this in your '59. Post the numbers that are stamped just behind the distributor and that will tell exactly what it was installed in originally.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-21-2022, 04:05 PM | #3 |
Re: Casting numbers
MJN nailed it.
Check the serial number on the block This list goes to 57 for 235 engines http://chevy.oldcarmanualproject.com/models/engine.htm If you scroll down to 37/83 it shows how to figure out the engine serial number on a 59. The 59 block should have an F or T, 3 digit number denoting month and day and a letter denoting the model it was built for. This is the engine serial number page.
06-21-2022, 06:58 PM | #4 |
Re: Casting numbers
F822HE it looks like but its pretty dirty
06-21-2022, 07:39 PM | #5 |
Re: Casting numbers
Your original assumption seems to be correct. 57 engine built in Flint Michigan on August 22 and a regular production engine.
One has to believe that that was what a former owner found when they went looking for an engine to replace the one that was in it.
