06-24-2022, 07:22 AM | #1 |
You all are a bad influence
on me....
just picked up this '68 stepside hopefully to get my grandson interested in something other than electronic devices....he will be 15 in Sept Decent truck needs work, has a good running rebuilt 350, 350 turbo, 3.07 gear, new seat
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-24-2022, 07:43 AM | #2 |
Re: You all are a bad influence
Not a bad looking truck at all. Good sized tires that fill out the wheel wells. Hope you can get your grandson to go old school.
06-24-2022, 07:44 AM | #3 |
Where are you finding these 67-68 red shortbed step side trucks ? Double the trucks and double the fun !
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-24-2022, 08:16 AM | #4 |
That's a darn nice little truck right there. Want to adopt another grandson?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-24-2022, 08:17 AM | #5 |
Aw.
I'm not sure much influence from us was required for that one. K [Edit - not to be opportunist, but - call me if it doesn't work out or you want to sell. I'm serious.]
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-24-2022 at 08:49 AM. |
06-24-2022, 08:46 AM | #6 |
Darn nice!!!
06-24-2022, 08:49 AM | #7 |
20' Daredevil (Ret)
We might be a bad influence on you..... but you are clearly a good influence on your grandson!
06-24-2022, 09:13 AM | #8 |
Thanks for the kind words...
someone has lowered it with springs up front.....but the lower A arms are sitting on the bump stops First order of business.....put stock springs back in with drop spindles and disc brakes up front....just got the kit.. Now if Grumpy will turn loose of that spare sway bar...I'll be all set with the front suspension...! I had this bumper off my 67 project....it will have new ones BTW thanks to Grumpy... the '67 is at body shop now...
06-24-2022, 09:27 AM | #9 |
Darn nice find.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
06-24-2022, 09:55 AM | #10 |
Awesome find! Seems that the previous owner did a pretty nice job refreshing the engine compartment! Maybe y'all can work on it together and then he can buy it from you! That would be a sweet first ride! That bumper you swapped on to it looks much better too!
'72 C10 Long Bed Stepside Putting my Grandfather's truck back on the road: http://www.67-72chevytrucks.com/vboa...d.php?t=829659 |
06-24-2022, 12:07 PM | #11 |
Very nice!
06-24-2022, 12:23 PM | #12 |
Grampa what about me? I want one too!!!
Take Care Troy |
06-24-2022, 03:12 PM | #13 |
Nice truck. Grandson should really like that. Looking forward to the updates.
06-24-2022, 03:46 PM | #14 |
Your disc conversion thinking is spot on, my opinion.
I’m wondering about that Astro van master cylinder, the pickup cams with? |
06-24-2022, 04:21 PM | #15 | |
I have a new dual diaphragm booster and disc/drum MC that will be going on with the front discs...
06-24-2022, 10:22 PM | #16 |
You need to look up "bad influence". That's a nice truck, and helping out your grandson is a very good thing.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-24-2022, 11:17 PM | #17 |
If that was a red 69 GMC and I had enough money I'd be trying to buy it off you, would match my father's first truck.
06-25-2022, 08:45 PM | #18 |
Funny how when you hang around these old trucks, the fever sneaks up on you. That will (and already is) , make a super nice pickup. I love 68s and I love swb trucks. I always shyed away from stepbeds cause it was hard to make lower molding look like anything. In my older years, I have come to like solid stepbeds. Good luck with it.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
06-26-2022, 12:39 AM | #19 |
R.I.P. E.S.L.L.
Nice truck The motor looks cleaner than my underwear.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
06-26-2022, 07:58 AM | #20 |
That M/L van master cylinder is a nice unit.
I had one on my Chevelle for a little while. After going through almost the entire catalog of GM master cylinders (a GM brake development engineer can do that sort of thing) that is the one I settled on. It resulted in really nice feeling pedal travel, force and overall feel. The only problem....was that front reservoir for the rear brakes was SO SMALL. When mounted on a passenger car the m/c is tilted at quite an angle. I had to park at the end of the driveway (where the ramp angle was steepest) and jack the back of the car up just to top off the m/c. In hindsight, one could probably pop the reservoir portion off the aluminum base and replace it with a different plastic piece from a pickup if the size proved to be a problem. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-27-2022 at 09:46 AM. |
06-26-2022, 08:01 AM | #21 |
What are the brand and part #s on those radiator hoses ? Is that engine sitting in the 6 cylinder location ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 06-26-2022 at 08:33 AM. |
06-26-2022, 08:59 AM | #22 |
Looks like 8" wheels hiding behind those wheelcovers. Probably rallyes or wagon wheels
06-26-2022, 08:37 PM | #23 | |
started the front disc swap today....mainly disassembly and cleaning stuff man this thing was greasy and crusty....! upper arms were tight...lower gets new shaft and bushings
06-26-2022, 08:41 PM | #24 | |
It's almost ready for that sway bar you're wanting to sell me....did you find it yet ? ..... I'll come and get it.....
06-26-2022, 09:25 PM | #25 |
Who Changed This?
Looks like at least three people beat me to the grandpa joke. I sure hope your grandson likes it!
