I need a drivers side lower control arm?
We tore my dads 68 down. Swapping out drums for disc up front and drop spindles. Got the passenger side buttoned up and the upper drivers side done. CAN NOT get the factory ball joints out from the lower control arm. Anybody know where I can pick one of these up?
![]() Join Date: Aug 2015
Re: I need a drivers side lower control arm?
if you cant find one closer, i took the uppers and lowers off my 1972,went tubular, pretty sure theyre the same
you can have the one you need for the ride i can box up im in indiana 46901
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
![]() Join Date: Mar 2003
I've rarely seen where the BJs are spot welded in. Look closely. Never seen one that wouldn't come out with a BFH
Who Changed This?
![]() Join Date: Jan 2013
You're on the other side of the country, so I can't help. Do you know anyone with a hydraulic press? That's how I did mine. And, yes, I've also seen where some have been welded in.
![]() ![]() Join Date: Jul 2002
EdB used to have his lowers tack welded in on the original lower A-Arms. they just wore out over time and that is how he kept them from popping in and out over bumps/holes in road. Glad they finally got replaced. I tend to agree with kwmech that they may be welded in, which normally means they will need welded in again to keep things fit. I would look for another a-arm also.
#6 | |
That might be an option as I have not came across any in my search. We have tried everything.. Brute force, heat.. **** aint coming out... My buddy is gonna let me know if he cant wrangle one up before he comes back down to help me put it all back together.. So if not, I will def be hitting you up. Thanks |
I got creative years ago and made some solid steel rings to replace the folded out sheet metal where the ball joint presses in and came up with this. Ground out the ring and opened up the hole with a drum sander and welded this in
pictures
Take a wire wheel around both sides, clean off thoroughly. Mix atf and acetone in a container 50/50 big enough to fit the end of the control arm in. Prop the balljoint end down in the container and make sure the entire balljoint is submerged. Cover up with a towel to minimize acetone from evaporating. Leave for 24 hours. It should come out with appropriate technique.
It will come out. If you give up take it to a shop with a press. By the way are you using an actual balljoint remover?? You are giving up too easily.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
![]() Join Date: Oct 2020
If I am not mistaken, the control arms are the same through 84.
![]() Join Date: Sep 2002
#12 | |
![]() ![]() ![]() Join Date: Jan 2018
Not sure on the difference between 3/4 and 1 tons though
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#13 |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#14 | |
![]() Join Date: Mar 2022
I am looking for both lower control arms for my 1972 C10 Big Block truck. Thanks, Brian |
#15 |
yes i do still have them, waiting on WPSharpshooter to respond, he has first chance
#16 |
#17 |
Hi
brianb3001 this is not the way this works, i am not listing this item or item's for sale, just trying to help a member out wpsharpshooter has first chance if you're looking for a set, check parts for sale Thank You
