AC Brackets &Sanden comp.
So trying to conevert factory AC over to new sanden comp. and all the other goodies my ? is will the new comp. fit in my original brackets or will I need ones ?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Nov 2018
Re: AC Brackets &Sanden comp.
Sanden makes a compressor that is a direct bolt in to your original. Only difference is it's aluminum and about 20 +/- pounds lighter.
Try these guys they will have anything you need in stock and are extremely knowledgeable.
https://autoacsolutions.com/products...-and-tube-kit/ |
There are a couple options for bolt in replacement compressors. Pro6ten or S6 I think these are the same unit. I've heard they are a denso body not sanden but I could be wrong.
Four Seasons also makes a new replacement Summit
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
I purchased a sanden 508 comp. off the classified and was going to swap it in place of my original . Wanted to know if it will fit or if new brackets are needed
I used an ICT billet bracket to mount a 508 compressor on my 327. It fits perfectly and the belt alignment is right on.
#8 | |
Who Changed This?
![]() Join Date: Jan 2013
Thank you Steeveedee it is. I bought this last December from Joes Junk a guy here on the forum. Great guy. I rebuilt the whole AC system and got everything I needed from Auto AC Solutions. JW helped me and was a pleasure to work with. Extremely happy with all the parts. Replaced everything except for the evaporator. Here's what it looked like when I got it. Everything was there just needed cleaned up a bit.
#10 | |
https://67-72chevytrucks.com/vboard/...1&d=1659018114 |
#11 | |
#12 | |
New Member
![]() Join Date: Mar 2021
#13 |
Yes the kit the link takes you to and no trouble at all mounting bolted right up. Brackets bolts and all included with the condenser, dryer, and lines. They even include a new rubber grommet where the lines go through the core support. I ended up sending an email on a Saturday asking for someone to call me on Monday since I needed a compressor also. JW that helped me called me that day right after I sent the email even though they were closed.
#14 |
Also if anyone is interested they sent me the new hoses already made up. No cutting, fitting, etc and then taking them somewhere to get crimped. Want to make clear I did not know these guys or have I spoken to them since. Just extremely happy with the service and parts.
#15 | |
New Member
#16 | |
