08-14-2022, 07:47 AM | #1 |
S-10 interchangeable parts
I have access to a 98-99 Chevrolet Blazer. Will the front suspension bolt to a 95 frame?
Will the Blazer rear go in the 95 S-10? Bolt up, or will I have to move perches? Setting things in motion for a frame swap. Never pulled down/put together many S-10's. Scott |
08-14-2022, 08:05 AM | #2 |
Re: S-10 interchangeable parts
Both are 4WD. Forgot the most important part.
Scott |
09-09-2022, 08:14 AM | #3 |
The front suspension should bolt in ok. I did yours backwards. I had a 96 blazer and put control arms on my 2000 s10 front end. The Blazer rear end i believe is wider than the pickup drum to drum.
09-11-2022, 02:46 PM | #4 | |
4wd rear is four inches wider than 2wd, truck or Blazer.
