08-24-2022, 01:56 PM | #1 |
Worlds most accurate oil pressure gauge?
Check this video of my oil pressure gauge.
https://www.youtube.com/shorts/jSxa4LJeldo My theory is that it has become sensitive to the oil pressure pulsations of the oil pump. |
08-24-2022, 02:45 PM | #2 |
Who Changed This?
Re: Worlds most accurate oil pressure gauge?
Somewhere there is oil leaking, internally. There shouldn't be any pulsations due to the oil pump.
08-24-2022, 07:36 PM | #3 |
08-25-2022, 02:39 PM | #4 |
I hooked up an aftermarket gauge I had laying around and it read nice and smooth. I am not sure how a mechanical gauge wears out, I suppose it could be on its way out.
The truck is LS swapped. The LS uses an 8-9 gerotor oil pump which would produce pulsations, but I would think you would have to be reading pressure closer to the pump itself vs the back of the block. |
08-26-2022, 08:13 AM | #5 |
I can't imagine an internal problem in oil flow that could cause such an instant response. I agree, the gauge must me failing. Until you replace it you can enjoy the privilege of having the world's most accurate oil pressure gauge
08-27-2022, 11:09 PM | #6 |
For fun, ditch the 1/8" line and hook up a 1/4" line... then watch the gauge really move! To be fair- I do have autometer mechanical gauges, but with the bigger line you get a more accurate reading.
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
08-27-2022, 11:38 PM | #7 | |
Who Changed This?
As for Steve1967's comment, the only thing I'd expect is more rapid response to a change in oil pressure, but I'm not convinced that it would be that rapid. Again, I don't have an explanation, but that gauge doesn't agree with any oil pressure sensing I've ever seen.
08-28-2022, 09:26 AM | #8 |
Post Whore
Did this phenomenon start happening out of the blue?
It could be caused by the oil pump pumping air. Is the oil level correct? Does the oil look like it's full of small air bubbles. As Steeveedee said you could have an internal leak that is aerating the oil. You might pull the distributor to inspect the drive gear and the oil pump drive for wear. It may not be the problem but, changing the oil filter is easy and it's not impossible that it could be the issue. I don't believe that the small brass gears in the guage will last very long with that much movement. Good luck and keep us posted.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
