08-27-2022, 01:06 PM | #1 |
Tripod Mirror washer order?
Got one of those after market tripod mirrors for the doors. Came with a many washers including a couple of nylon ones. No instructions. I'm guessing the nylon washers are sandwiched under the elbow (bolts on from bottom) somewhere on top of the tripods. Does anyone know the correct order and number of washers?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
08-28-2022, 02:03 AM | #2 |
Re: Tripod Mirror washer order?
I don't have mirrors like those, so I'm only guessing. But I think the Nylon washers are for use in a spot where you want to be able to pivot the mirror without using a wrench.
08-28-2022, 04:08 AM | #3 |
I would guess the nylon washers go in the same place as the fiber washers on the stock type mirrors and the hard washers go under the nuts. Nylon goes against the mirror flange and against the mirror mount brackets. Fiber washers are present in all those locations on stock type mirrors. A total of eight fiber washers for both mirrors
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 08-28-2022 at 04:15 AM. |
