Old 09-10-2022, 02:49 AM   #1
FullOutPwr
Choppin Block back half install help
So I am installing the Choppin block back half on my 67. I’ve already cut the frame but thankfully left a bunch as the no instructions thing wanted me to be triple sure.
I removed one cab mount and went to check the new Choppin block cab mounts since they center the whole backhalf and new trailing arm crossmember. The new cab mounts have a larger bolt pattern than my stockers. I’m not sure how to line these up, especially as I haven’t seen anyone else on YouTube or google search notching holes just opening them up more for the larger bolts.
Any help? Or did they screw up and send me wrong stuff? The no instructions for this kit make me wish I had thought harder about the brand I went with.
67 C10
Choppin block backhalf
KP Components front dropmember
US Mags Rambler 20s
FullOutPwr is offline   Reply With Quote
Old 09-10-2022, 08:26 AM   #2
Re: Choppin Block back half install help
No instructions? Just spend your money here, chop your truck in half, and good luck with it? Unbelievable!
Old 09-10-2022, 11:00 AM   #3
Sheepdip
Sheepdip's Avatar
Got any pics? That would certainly help.
Sheepdip is offline   Reply With Quote
Old 09-11-2022, 07:21 AM   #4
FullOutPwr
Sure do if they’ll load.
67 C10
US Mags Rambler 20s
Old 09-11-2022, 07:23 AM   #5
FullOutPwr
They used to just throw all the hardware in one massive bag and called it a day. They at least bag the hardware and tag it for each piece now.
There’s a reason I bought the KP front.
67 C10
US Mags Rambler 20s
Old 09-11-2022, 09:21 AM   #6
kev2809
low n' slo
kev2809's Avatar
do you have the "extreme" kit? i found the backhalf kit on az pro performance and if you scroll down to "whats included", just under it is a link to instructions. hopefully its the same kit as yours.
https://azproperformance.com/product...-kit-63-72-c10
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-11-2022, 05:48 PM   #7
Jason Banks
Jason Banks's Avatar
I wonder if that's an oddity of the 67 frame. When I cut my frame for shortbed conversion and had to move the cab mounts back, I made a CAD template of where the holes were. I just looked and my cab mounts were 5 5/16 wide by 2 11/16 high... 5.3125w and 2.6875h
Jason Banks is offline   Reply With Quote
