will a 1980 blazer rear bumper fit on a 67 fleetside?
I did a search but had no luck.
Will a 1980 Blazer rear bumper work on a '67 fleetside without modifying brackets?
I got a bench seat baby, you don't have to sit over there. |
![]() ![]() ![]() Join Date: Jan 2018
Re: will a 1980 blazer rear bumper fit on a 67 fleetside?
No, the brackets are very different between the two, so modification would be necessary either at the bumper side of things or on the frame side of things
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
