Torque settings cab/radiator mounts
Factory manual says 35-55lbs for radiator supports. I think I see 70-90 for front cab mounts and 35-55 for back cab mounts. 20 lb spread for both. Torque to middle of the spread? 72 C10
![]() Join Date: Dec 2013
Re: Torque settings cab/radiator mounts
Mock it up using the low settings until your body lines and gaps look good then torque to fine tune them , Just because your using new mounts doesn't mean it's going to drop into place , You'll be moving things around to get it nice . :chevy
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Nov 2018
Grumpy always has common sense.
