Cab Roof Lights
I'm interested in putting some clearance lights in my K-20. I have several questions:
1 With a conventional roof skin, none raised, is there plenty if clearance between the roof skin and the cab inner panel to drill mounting holes and instal wiring? 2 Can someone give me some dimensions from the Center of the cab, where the center light mounts to the two adjacent lights that are fairly close to the center one, and also the distance from center, or outside edge of cab, to the center of the ones closest to the outside. The distance back from the front edge of the roof also. 3 Are the Pacer lights a Chromed Plastic base or the pot metal, like the original? They seem awfully cheap to be the real deal 4 NAPA sells them, but there over 50 dollars each and they don't indicate if they're plastic or not I'm also considering E-Bay. I'm talking about the Tear Drop style, something 77s I think they're called for the original style. Thank you!!
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: Cab Roof Lights
Yankee 77.
Re: Cab Roof Lights
I put a set of vintage Do Rays, like these, on my Suburban
edit: I think if you search you'll find the installation dimensions from the assembly manual
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
BlahBlahBlah
Re: Cab Roof Lights
I asked a mod to shut this post down since it was posted here in error and restarted on main part of board 67-72 area.
