10-31-2022, 06:19 PM | #1 |
Picture of factory tail pipe exit on 71ish SWB 402 anyone??
My exhaust guy would like a reference. Don't suppose it matters LWB and SWB. I'm working on a 71 SWB, 402. The pipes exit the rear sides someplace.
A picture and three measurements appreciated a lot....... .Horizonal distance from the rear fender to tail pipe's exterior: .Vertical distance from the rear body's bottom to tail pipe's exterior: .Inward or outward distance from the body's bottom to tail pipe's tip:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-31-2022 at 09:44 PM. Reason: Clarification |
10-31-2022, 06:26 PM | #2 |
Re: Picture of factory tail pipe exit on 71ish SWB anyone??
V8 or 6cyl?
10-31-2022, 07:46 PM | #3 |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-31-2022, 11:36 PM | #4 |
hi Tony,i can get you some measurements tomorrow if you like.here's the new Waldron tailpipes on my 72 truck.they are the same as the originals i took off except 2 1/4 diameter pipe rather than 2 inch because i asked for them that way.everything fit right back on the factory hangers also.
11-01-2022, 01:30 AM | #5 | |
11-01-2022, 10:51 AM | #6 |
11-01-2022, 10:52 AM | #7 |
The V8 pipe exit appears to be same position as 6, which is what I have. Since Greg is sending you his measurements I will hold off. Also I used stock hangers but 2" pipe and had the shop just weld on a chrome turn down tip positioned where "I" wanted it in terms of how far in/out I wanted it so it may not be exactly stock position
11-01-2022, 12:40 PM | #8 |
Thanks for all the help, and I appreciate it again Greg, you've helped me out a lot.
11-01-2022, 04:51 PM | #9 |
11-02-2022, 04:20 PM | #10 |
Maybe a dumb question, but did they do a single exhaust output for the SBC in these trucks? I know that was common in the sedans of that era, but unsure about the trucks.
Thanks! |
11-02-2022, 05:30 PM | #11 |
not a dumb question at all.they certainly did do single exhaust for these trucks with a small block.they all didn't have duals.i worked in a muffler shop when i was a kid so i saw lots of them.recently when i did the exhaust on my truck,i contacted Walker but the answer i got back was that they no longer made the parts for our trucks.i've used Waldron's in Michigan for exhaust parts for several projects now,they still show a single exhaust system for these trucks.all the best.Greg.
11-02-2022, 10:01 PM | #12 |
Who Changed This?
I've seen it mentioned here somewhere that trucks with small block engines only ever had single exhaust with a y-pipe. I worked on a ton of vehicles from '70 to '72, and only recall a very few dual exhaust vehicles, but no SBC trucks, and I can count on one finger a SBC 400 with dual exhaust, in an Impala. Rare bird, I guess. BBC trucks were always dual exhaust in those years, IIRC.
11-03-2022, 02:06 PM | #13 |
LMC sells a single exhaust for a 6 Cyl. Box with muffler that came with mine said Made in Michigan IIRC....don't know if it was Waldrons but system fit was good
11-03-2022, 10:22 PM | #14 |
Exhaust installed, great guy & work. 2.5" fronts and 2.25" rear. Turbo mufflers, they're pretty quiet when not broken
https://www.youtube.com/watch?v=hhM_Mg8MHGA&t=136s
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-03-2022 at 10:33 PM. |
11-04-2022, 12:26 AM | #15 | |
11-06-2022, 11:10 PM | #16 |
Sure did. Mine is a 350 with a Y pipe and single tail pipe that exits just aft of the left rear.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
