11-02-2022, 04:36 PM | #1 |
Question about wiring
I'm in the process of wiring on my restoration 70 c20
I'm using the factory harness Positive cable to starter Purple wire from harness to starter Wire from positive terminal to junction block on pass fender which I assume powers the fuse block ? My issue is I'm getting power to just a few fuses, no switched power and nothing to starter with key Is rhere some other source to power ignition switch? |
11-02-2022, 04:56 PM | #2 |
Re: Question about wiring
Should have a 12v feed to the ign switch and a working ign switch to feed the fuse block
11-02-2022, 05:06 PM | #3 |
11-02-2022, 05:36 PM | #4 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=185856 |
11-02-2022, 10:16 PM | #5 |
BTW there should be a fusible link between the battery and the junction block...
11-03-2022, 06:56 AM | #6 |
11-03-2022, 07:19 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
A fusible link is a short section of sacrificial wire spliced into the various power feeds for accessories. They are usually 4 wire gauges smaller that the power wire they are designed to protect. Here's a good explanation, https://www.youtube.com/watch?v=Tg7K343N5w0&t=138s
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-03-2022, 07:25 AM | #8 | |
11-03-2022, 07:45 AM | #9 |
It should never blow, it only does if there is a really bad short. Normally it should last for decades. Our trucks normally have 12 guage wire as the largest unfused wiring in the truck, so to protect that you would use a piece of 16 gauge fusible link wire about 6 to 9 inches long to connect the battery to the junction block. It has a special non-flammable insulation and they are usually grey. Pieces of fusible link wire are sold in car parts stores, usually in a blister pack.
11-03-2022, 07:50 AM | #10 | |
11-03-2022, 09:03 AM | #11 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-03-2022, 09:11 AM | #12 |
So I'm getting power to everything except the purple wire to the starter via ignition switch. This is an automatic converted from a 4 speed. Was there a NSS with the 4 speed from factory I'm missing ? I don't see any plugs under dash for one
11-03-2022, 09:43 AM | #13 |
I figured the starter issue out. Battery problem. Thanks
