Old 11-20-2022, 10:36 PM   #1
RDrancher
RDrancher's Avatar
Porterbuilt Rear
Had a friend drop off a few pieces from a PB rear bagged kit. Got the trailing arms, trailing arm crossmember for a one piece driveshaft and an adjustable track bar. I won't be bagging my '64 longbed, just doing a 4" rear spring drop. I'll for sure use the track bar, but is there any reason to go to the trouble of using these pieces and converting it to spring drop? Simplicity? Strength?
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 11-21-2022, 01:45 PM   #2
SCOTI
SCOTI's Avatar
Re: Porterbuilt Rear
The front T/A x-member/mount has multiple options for the placement of the arms which helps dial in driveline alignment/angles. They also have pass through access for exhaust which should make exhaust routing easier.
Pieces are stronger/beefier vs stock stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-21-2022, 06:17 PM   #3
RDrancher
RDrancher's Avatar
Thanks Scoti, I was hoping to get your take on it. I'm planning on dropping in an auto trans as well, and it couldn't hurt to be able to adjust angles with the new driveline.
Old 11-21-2022, 11:17 PM   #4
SCOTI
SCOTI's Avatar
No problem. Anything that offers adjustability even @ milder 6" drops is better vs limited/no adjustment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
