12-24-2022, 10:54 AM | #1 |
Kick panel vent gasket
I bought a set of gaskets online and I'm not really happy with them. The material is kind of cheap and I cant get them to fit real good. I'm thinking about grinding off the rivits that hold the 2 plates together and installing a solid piece of rubber then bolt it back together. Possible use a piece on inner tube. Anyone done something like this?
12-25-2022, 08:44 PM | #2 |
Re: Kick panel vent gasket
popeyestruck
i used truck tire innertubes and just traced out from the plates --didnt drill out rivits i just carefully pryed open the plates and fit the rubber in --wd -49 helps --then i carfuully hammered the plates closed . truck inner tubes are in my opinion thicker and i find much better , hope this helps |
12-25-2022, 09:28 PM | #3 |
i just drilled out rivets and cut some felt i got from a craft shop then put back plates together with pop rivets
12-26-2022, 12:06 AM | #4 |
I'm with Daze57, I'd hit my buddy at the tire store for a Truck tube that they can't repair that has enough square inches of decent rubber left to make a gasket or three.
12-26-2022, 07:04 AM | #5 |
Thanks . I'm going with some inner tube. The gaskets that I bought are a joke
