Old 01-10-2023, 08:30 PM   #1
KyleSeal
KyleSeal's Avatar
Seasoned Patina Guys: what do I do?
Going back together on the interior to the cab, and I have the dash out, ready for reinstall. But I plan on painting the outside (driver facing) of the dash in a semi gloss clear, what do yall normally do to the backside? I'd hate for the rust to continue, should I clear coat it to seal it or do the work to put an actual sealer on it? This will be a year round driver.
Size:  46.6 KB Name:  IMG_4374.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-10-2023, 10:17 PM   #2
davischevy
davischevy's Avatar
Re: Seasoned Patina Guys: what do I do?
This is what I use. I spray it on everything inside and out if it has rust.
https://www.lowes.com/pd/LOCTITE-Rus...da8a878d6e0563
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-10-2023, 10:36 PM   #3
chewychevy67
Just remember that the radio and other pieces ground thru their mounting to the dash.
chewychevy67 is offline   Reply With Quote
Old 01-10-2023, 10:38 PM   #4
PowerdbyChevy79
PowerdbyChevy79's Avatar
This is what I use.. works pretty good..
https://www.amazon.com/POR-15-45818-...00MBFOHEW?th=1
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-10-2023, 10:41 PM   #5
Getter-Done
Getter-Done's Avatar
Larry
You just (Cost) and saved me Some money.
I got a case of it I will pick up tommorrow.
84 Chevy K-20
Old 01-11-2023, 10:43 PM   #6
KyleSeal
KyleSeal's Avatar
What would you suggest? I know Im clearing the exposed part of the dash, but the rear of the dash, what would you do? Im fine with leaving it natural if you dont think it would be an issue, just want to know what the experienced guys do.
Old 01-11-2023, 11:35 PM   #7
chewychevy67
I am not sure. I was just pointing it out so when you put it all together you don't have to chase grounding issues. Those are not fun. Normally I just leave under the dash alone on mine pending that they aren't super flashy with rust. Or add a ground block and ground things using separate wires.
Old 01-11-2023, 11:48 PM   #8
davischevy
davischevy's Avatar
I have been using Loctite extend for 30 years to seal rust. If you use serrated washers on grounds, you shouldn't have a problem.
Before you clear the top of the dash, try using the Extend. It leaves a finish that doesn't look "fake". Just scuff with a pad, wipe it down and spray it on.
other Larry
Old 01-12-2023, 07:46 AM   #9
Another great rust treatment I've been using a long time is Permatex Rust Treatment spray. Both Xtend and the Permatex can be painted directly. I use it alone on all my rusty metal signs outside. There are many products out there but many leave oxidation crust that must be dealt with.
Old 01-12-2023, 11:50 PM   #10
KyleSeal
KyleSeal's Avatar
I ended up going with this on the inside of the dash. I tested it out on an old roof skin I had that had the same level of rust, and I like the outcome. Not waxy or wet, dried well. I will still clear the exposed side of the dash, as it will match my interior that is worn and will be satin cleared. But I think this Loctite stuff works pretty well.
dash, paint, patina
