Old 01-24-2023, 09:41 PM   #1
aj_89
Another RPO code request
I have just purchased a '87 jimmy and while waiting for some pieces to arrive i thought I would check into the RPO codes to see what options were selected when new. I have gone through just about every post mentioning RPO codes and have deciphered most of them, but I still have a few left overs that I cannot seem to find. Can anyone translate these last 3 for me please?
XU2
23D
29K
Thank you
aj_89 is offline   Reply With Quote
Old 01-25-2023, 01:11 PM   #2
wazzabie
Re: Another RPO code request
That is odd your SPID does not have friendly name descriptions.
wazzabie is offline   Reply With Quote
Old 01-26-2023, 04:03 AM   #3
aj_89
So it turns out the first code was XUZ which is the front tire size 31x10.5R15, still coming up blank on the 23D and 29K codes.
Old 01-26-2023, 10:06 AM   #4
Keith Seymore
Keith Seymore's Avatar
If that is the case there should also be a YUZ (rear tires) and ZUZ (spare) code.
It was structured this way so that a customer could buy different rear tires than front tires (and different spare, too).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-26-2023, 10:22 AM   #5
Keith Seymore
I found an old booklet in my drawer from 1998 (about 10 years newer than I would have liked).
It does not show a 23D, but it does show 23C a couple times for a couple different trim combinations (blue cloth).
Similarly, no 29K but there is a 29L which is a "secondary color" - also blue. Maybe 29E would be a better example which is also a blue cloth trim code.
The info packet in the GM Heritage Center archive shows code 29 as an available exterior color - Midnight Blue. I do not see a 23 code anywhere for interior or exterior.
K
https://www.gm.com/content/dam/compa...olet-Truck.pdf
https://www.gm.com/content/dam/compa...t-Suburban.pdf
1979-1986
1986 - 2019
Old 01-26-2023, 10:35 AM   #6
Keith Seymore
That IS interesting, because my '87 SPID DOES have the friendly name descriptions.
All square SUVs were built in Flint (as supported by the OP's SPID, which shows a VIN code of
H = 1987 model year
F = Flint Assembly plant
500xxx = sequential portion of VIN)
So - to summarize - two vehicles built in the same model year in the same assembly plant down two different lines: two different SPID styles.
Mine's a Chevy, his is a GMC. Maybe that's the difference?
Or maybe when during the model year it was built? Mine was built in September of '86.
K
1979-1986
1986 - 2019
Old 01-26-2023, 01:24 PM   #7
Keith Seymore
XU2
23D
29K
Thank you
I'm sorry - I'm spending way too much time on this -
Another thing you could do would be to send away to the Heritage Center for your original build invoice. That would tell you all the build codes (and I assume option names), time built, original selling dealership, pricing, etc.
It was $50 when I did mine.
K
1979-1986
1986 - 2019
Old 01-27-2023, 04:33 AM   #8
wazzabie
K
Hi Keith, Is the vehicle invoice, build invoice and dealer invoice the same document? Also at the dealer would there have been an order invoice?
Old 01-27-2023, 04:45 AM   #9
wazzabie
H = 1987 model year
K
Hi Kieth, I didn't know that GMC had there own assembly lines that were not shared with Chevrolet. That could explain the difference in the SPID format. At the top of your SPID what does the typed number 515906 represent?
Old 01-27-2023, 11:39 AM   #10
Keith Seymore
Not quite correct.
Line 2 was Blazer/Suburban specific, but both Chevrolet and GMCs went down the same line.
Similarly, Line 1 was specific to pickups only, but both Chevrolet and GMC pickups went down that same line.
GMCs were about 1 out of every 9 builds.
Chevrolet VIN sequence started at 100001 and GMC VIN sequence started at 500001 for this particular year.
I do not know.
It is not the order number, since that appears at the bottom.
I also know it is not the build sequence number, because my sequence number ends in "87".
I don't have any guesses beyond that, unless it is some kind of vehicle indicator from before the General Assembly build sequence was established (Flint has the opportunity to shuffle builds around after body shop/before paint, and again after paint but before trim).
K
1979-1986
1986 - 2019
Old 01-27-2023, 11:52 AM   #11
Keith Seymore
I'd say they would all contain the same information, but might be slightly different formats and prepared at slightly different times in the process.
Yes - I could imagine there would be an "order invoice" as well, perhaps generated from any hand written or early worksheets generated while working directly with the customer.
K
1979-1986
1986 - 2019
Old 01-27-2023, 12:39 PM   #12
wazzabie
Not quite correct.
I do not know.
K
Hi Keith, I listened to your interview on c10 talk which was really fascinating. It takes me hours to try and aligned the fender gap. The assembly line only had one minute and would use three body shims until someone down line complained about the gap. After the fender was aligned did the fenders get another shot of paint? I ask because some of the fender bolts are the same color as the fender.
Old 01-27-2023, 04:56 PM   #13
Keith Seymore
Thank you -
No additional paint, at least in the normal process.
All the fender attaching bolts should be either black or cadmium silver. (one vertical bolt at the a pillar, one horizontal bolt in side the door, one horizontal bolt at the bottom of the fender dog leg - shot outboard from the pit - and about 7 at the nose of the fender to the radiator support).
I suppose if there was some paint repair going on out back some overspray could have gotten on some of the bolts.
K
1979-1986
1986 - 2019
Old 01-27-2023, 10:59 PM   #14
rwjtexas
Junior Member
Good Evening,
I have a 1985 K5 Blazer with Paint codes 29 Midnight Blue and 21 Lt Blue Metallic with the two tone package the Midnight Blue was the primary color and the Lt. Blue was the center body stripe.
My code for 23D is for the LDD4 High Back Custom Cloth Seats (Blue)
My code for 29K is for the paint code for the fiberglass top. (Midnight Blue)
Look at the bottom of my glove box tag numbers showing on left and right side.
I hope this helps.
rwjtexas is offline   Reply With Quote
Old 01-28-2023, 09:45 AM   #15
Keith Seymore
Originally Posted by rwjtexas View Post
Good Evening,
I hope this helps.
Perfect; excellent. Nailed it.
Thank you. All of my posts have now just become a long way of saying "I don't know".
_
1979-1986
1986 - 2019
Old 01-28-2023, 12:35 PM   #16
Keith Seymore
In hindsight, this makes perfect sense.
23D "looks" like an interior code.
For exterior colors "U" (or upper) is for the primary exterior color, like 29U. "L" (or lower) is for secondary colors (like the inset, or across the bottom) so "K" must be for the separate fiberglass top.
For many years they were available only in black and white, but in later years became available in some limited body colors.
K
1979-1986
1986 - 2019
Old 01-28-2023, 03:58 PM   #17
wazzabie
Good Evening,
I hope this helps.
Does your blue painted K5 removable top have the textured finish or is it smooth?
Old 01-28-2023, 08:58 PM   #18
rwjtexas
Junior Member
Mine is a mild textured finish. I am waiting on my second estimate for paint and body. The shop I am waiting on to advise price, tells me that they can place a textured coat back on it so I am good to go with that...
Old 01-29-2023, 11:52 PM   #19
wazzabie
I need to get my k5 top painted. I've thought about having it sanded smooth and then epoxy primer and then paint. A smooth finish while not stock maybe more durable.
Old 02-06-2023, 03:54 PM   #20
aj_89
K
You are Correct Keith, there are YUZ and ZUZ codes stating the same tire size
Old 02-06-2023, 03:57 PM   #21
aj_89
Good Evening,
I hope this helps.
Thanks rwj, I had figured it was something to do with colors but wasn't aware that there would be a second code for the roof, my Jimmy has been resprayed all white at some point in it's life so I totally gapped on the possibility of it being two toned originally. Thanks for the help!
