03-09-2023, 10:36 AM | #1 |
1967 (maybe 68?) Steering Column Assembly...
I recently decided to rebuild my 67's column (automatic) and have found very little info on these 67 (possibly 68 as well) columns, as they are a bit different.
The lower section seems to be the most different, so here are some pics for future reference, for anyone who runs into an issue figuring out how it stacks up:
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 Last edited by KyleSeal; 03-09-2023 at 02:40 PM. Reason: Correction to post |
03-09-2023, 10:38 AM | #2 |
Re: 1967 (maybe 68?) Steering Column Assembly...
Here's some of the assembled look... the 3/4 'band' clamp/brackets hold the lower bearing retainer and the shift arm assembly, I offset them just because that seemed to make sense to me. I gave everything a skim of wheel bearing grease before assembly, to keep them from drying up or corroding.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 Last edited by KyleSeal; 03-09-2023 at 02:39 PM. |
03-09-2023, 10:55 AM | #3 |
Very nice. I will probably be doing this soon on my 67. Thanks for the info.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
03-09-2023, 12:50 PM | #4 |
The steel washer and white plastic bushing are not supposed to be installed there. There should be a gap in that location instead to allow the shift rod arm to disengage from the detent plate when you pull the shift lever toward you.
The steel washer and white plastic bushing belong up at the top end of the column, below the piece that the shift lever attaches to. |
03-09-2023, 01:03 PM | #5 | |
03-09-2023, 02:39 PM | #6 | |
Mods - if you can delete my original photos, I will correct and repost.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
03-09-2023, 04:37 PM | #7 |
These are the updated photos - thank you guys for the correction!
03-09-2023, 05:10 PM | #8 |
Looks good!
03-09-2023, 06:46 PM | #9 |
Post Whore
That's really nice. Where did you find such a low mileage column? The shifter detents look brand new.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Tags |
1967, automatic, column, rebuild |
