03-13-2023, 02:43 PM | #1 |
Steering Component
There is a long tube in front of my front axel that connects the driver and passenger steering. Mine is rather bent from a PO. It is on my 72 Blazer. Any idea what this is called or where to source a new one? If it was on a 73 Blazer it would be called an adjustable tube 4 wheel drive according to LMC. Any thoughts?
Thanks for your help. |
03-13-2023, 02:51 PM | #2 |
Re: Steering Component
It's called the tie rod...as you said, it connects the steering knuckles together.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-13-2023, 06:55 PM | #3 |
Are you sure it's called a tie rod? The tie rod descriptions are just the ends that I keep finding. Not the actual like 5 foot long shaft.
03-13-2023, 07:27 PM | #4 |
It is the tie rod. A diagram from LMC https://www.lmctruck.com/1967-72-che...-4-wheel-drive They only sell the tie rod ends, notice "tie rod ends". If those are the ends, the center is the tie rod. Look for used in parts forum. I have seen them new, just do not remember the manufacturer.
Quick search turned this up https://www.oreillyauto.com/detail/c...tie+rod&pos=11 Measured and the stock tie rod is 52"
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 03-13-2023 at 07:45 PM. |
03-13-2023, 10:13 PM | #5 |
Center link
03-13-2023, 10:44 PM | #6 |
Not many have them for sale. Try Dwyane Tressler or Thomas
Some progress is better then no progress |
03-13-2023, 11:27 PM | #7 |
Amazon with free shipping https://www.amazon.com/Rare-Parts-RP.../dp/B000CK4ZT0
Found on ebay as well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-14-2023, 08:18 AM | #8 |
I may have one but would have to look this evening.
03-14-2023, 09:59 AM | #9 |
It's a non-wearing part so you may have difficulty finding a use one. Square body trucks may use the same part which will may help you find one.
03-14-2023, 11:07 AM | #10 |
I appreciate everyone's help on this. Would love to pay a board member for the part. 1rippen6 - if you have one, that would be awesome.
03-14-2023, 02:33 PM | #11 |
03-14-2023, 05:45 PM | #12 |
Sorry, as I was looking, I realized I used the last one a couple months ago.
03-14-2023, 07:21 PM | #13 |
No problem. I appreciate your time to look and see. It was worth a shot.
03-15-2023, 10:38 AM | #14 |
Active Member
I switched mine to the solid forged steel, I bought everything from Summit Racing
04-04-2023, 06:27 AM | #15 |
check with off-road design they have 3 different types to choose from. stock to super heavy duty.
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........ |
